Version 7.3
Fixed known display bugs.
v 7.2
v 5.0
v 4.1
v 4.0
v 3.1
Added French.
Added support for T-Rex Pro.
Found bugs fixed.
v 2.1
Fixed bugs in display AOD.
Added support for AOD.
Added Chinese translation.
v 1
Added English translation.
v 1.2 Added Spanish language
ScaredyCat
Post by ScaredyCat »
Ahh ok, thanks. I'm not going mad then ;)
Probably means my icon isn't aligned in the centre too, so willfix that :)
Version 6.1
Update v 6.1. Fixed weather alignment.
dilshadsys
Post by dilshadsys »
kevin2012
Post by kevin2012 »
Thanks. Will be really great if it also supports unpack gts 2 mini bin file even though it may not support creating.
Spiric
Post by Spiric »
How can i convert WF from T rex Pro to T rex?
Spiric
Disassemble it in this editor and use the resources from it to make a new dial for the T-Rex.
Not all features from T-Rex Pro are supported in T-Rex.
ShepsCrook
Post by ShepsCrook »
I'm unable to download from Dropbox oddly enough. It fails to download and acts like I need to log in. Anyone have any alternative download links for this stuff? Google Drive? something?
Slughorn
Post by Slughorn »
Hi friends.
The amazfit watch face editor 2 doesn't open many dials for the T-rex. I try to open as a compressed bin and it doesn't unzip it, what can happen?
Has thanked: 419 times
Been thanked: 2109 times
Slughorn wrote: 17 Aug 2021, 19:19
Hi friends.
I think , you can not open " T-rex " Because "AmazFit WatchFace editor 2 for Windows" Do not support it. This program support only "T-rex PRO"
If you would like to open "T-rex" BIN you can use " AmazFit WatchFace editor for Windows by SashaCX75 " to do it.
Link to Program :
viewtopic.php?f=29&t=1076
Slughorn
Post by Slughorn »
Sorry, the watch faces of the t-rex pro are the ones that won't open.
[email protected]
Post by [email protected] »
SashaCX75 wrote: 12 Apr 2021, 07:58
How does conventer GTR47ToGTR2 work?
Loads discs from T-Rex and saves as T-Rex Pro.
In Editor 6.1, I can't open it. The files are numbered 0000 not 0001 and the json layout is not loaded.
And I would like to add AoD to the reworked dial.
Slughorn
If you clarify which dials are not unpacked, in which version of the editor and on which system you are trying to unpack, then it will be clearer what the problem is. The editor does not work on 32 bit systems.
[email protected]
Editor v 6.1 and shouldn't unpack such dials. Converted dials have the older format. To work with such dials, the first message contains a converter combined with an editor. There is no AOD on such dials.
Slughorn
Post by Slughorn »
Thank you very much, I did not know that. I think now if it goes with the previous amazfit watch face.
Version 7.0
Elbruz
Post by Elbruz »
Thanks before for created this tools, I'm very helped to created my own watchface.
I've trying to edited watchface from other creator, but when I'm packed and compress the file after editing, the size of BIN file is larger than original file.
what happen for this problem?
how to create BIN file with small size ?
Thank you
evileyes
Post by evileyes »
https://amazfitwatchfaces.com/t-rex/view/7001
I'm using editor 2 to create this for Trex Pro,
it looks all good in the editor,
but its only black screen when installed to the watch.
so what is happening or what am I missing ??
evileyes
The first file must be a background or preview.
This watch face is made for Zepp E Circle and not for Trex Pro.
Saqibpiash
Post by Saqibpiash »
Please support for GTS 2 Mini
Version 7.1
spidercrab
Has thanked: 27 times
Post by spidercrab »
Not sure if this is exactly the right place to ask this question.
Is it possible to create WF's for the Zepp Z?
If not, as there are similarities to other round Amazfit devices, is it likely that this will be supported in WF Editor 2 or future versions?
spidercrab
I have not seen Zepp Z watch faces and cannot say anything about them. But judging by the size of the screen, the dials from GTR 2 should work.
Horatius80
Post by Horatius80 »
spidercrab
Based on the various information available, the ZEPP Z should only be a "disguised" GTR2 without a speaker
manzoorkhokhar
Post by manzoorkhokhar »
hello
i need converter which convert amazfit gtr 2 watch faces to gtr 47mm
here i found the concerter which convert gtr 47mm watch faces to gtr 2 but did not find any converter which can convert GTR 2 watch faces to GTR 47 mm
can anybody help
manzoorkhokhar wrote: 05 Sep 2021, 15:56
There is no such converter. You can disassemble a watch face in one editor and assemble a new watch face in another editor.
manzoorkhokhar
I am not such technical :( to do such difficult task neither know about any software which can do this task
anyhow Thanks for your time and response
Users browsing this forum: No registered users and 32 guests
