Is there any way for me to upload the watch face directly
Discussions on other topics.
Postmortem
Post by Postmortem »
Is there any way for me to upload the watch face directly to my watch instead of using the website to scan a QR code? sorry is this is a dumb question.
Has thanked: 1155 times
Been thanked: 278 times
Postmortem wrote: 20 May 2026, 12:41
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
I haven't tried it lately but I used to do this:
I install watchfaces from my Android phone this way:
1. download the .zip file to your phone. On Android, it goes into the Downloads folder.
2. clear the data/cache storage from the Zepp app.
3. load the Notify for Amazfit app (you need to set it up, get your watch's pairing code, etc. follow the instructions)
4. when all set up, click on the "Devices" icon at the bottom. Tap "Watchfaces" press the "hamburger" settings icon on the top-left. Select "Custom watch-face (.bin)"
5. This will open up the phone file manager. Select the Downloads folder. Then select the .zip file. Hit the "Install" button.
6. If all goes right, it will install the watchface.
7. Once you're done testing, do the storage app/cache wipe of the Notify for Amazfit app.
8. Open the Zepp app and re-login to connect it to the watch.
But the method asoo has put together makes it very easier to install from a Windows machine. But this method uses a QR code.
viewtopic.php?p=22231#p22231
Postmortem
taw_bip wrote: 20 May 2026, 20:43
Thank you!
Return to “Off-Topic”
