BLUE Color 0000FF gives error in BIP watch face making however ..
asadulhuq
Post by asadulhuq »
If I apply Blue color (0000FF) to the numerical digits, warning message comes while the .bin file is being made. The warning is as follows -
Trace|Loading image 2...
Trace|Image was loaded from file C:\Users\Asadul Huq\Desktop\MyBIPFace\10\10\0402.png
Warn|Dithering applied for an image. Resource in watch face will use only supported colors. You can't get back original image by unpacking watch face.
Trace|Loading image 3...
However, the actual image file shows the color correctly and the bip watch itself displays 0000FF (BLUE) color correctly. Then why that Warning message? See the following images-
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
asadulhuq wrote: 03 Mar 2019, 19:32
In image software,
disable (image anti-aliasing function)/disable (smoothing edge function) 。
Enable Pixelization function
asadulhuq
Post by asadulhuq »
Thanks.
