request Balance 2 iwc eternal
Anoniem
Post by Anoniem »
Can someone please make this watch face?
I include the images.
Iwc-Eternal-Calendar.zip
(1.14 MiB) Downloaded 4 times
Been thanked: 2115 times
I have a question. You're a WF Maker, and judging from all your work and the resources you provided, I think you should be capable of doing this yourself. Your previous work is of high quality, which means you should be able to create this watch face without much difficulty.
Furthermore, I found that you already have similar work, only the colors are different. Simply modifying with resources you attached should allow you to use it as you intended.
https://amazfitwatchfaces.com/gtr/view/24095
