- Amministratore
request Balance 2 iwc eternal
- Has thanked: 420 times
- Been thanked: 2115 times
You make a request about Balance2 in the T-rex area. Next time, please check before posting. This time I've moved it to the Balance area.
I have a question. You're a WF Maker, and judging from all your work and the resources you provided, I think you should be capable of doing this yourself. Your previous work is of high quality, which means you should be able to create this watch face without much difficulty.
Furthermore, I found that you already have similar work, only the colors are different. Simply modifying with resources you attached should allow you to use it as you intended.
https://amazfitwatchfaces.com/gtr/view/24095
This watch face was created based on your old watch face script.
I'm not sure if it meets your needs.
And regarding the moon symbol, I'm unsure of its accuracy as I'm not familiar with its workings. It currently uses 8 images moon progress same as your old watchface for display.
If it's incorrect, I won't be able to modify it because I don't understand how it works either.
Hopefully, this watch face will be useful to you for further modifications.
Moon with 8 images same as your old work
