Hi, would someone kindly fix the flickering seconds pointer of this watchface?
And if it is not too much work reducing the size of the data and all three pointers would be appreciated
viewtopic.php?t=4334
Flickering seconds pointer
- Has thanked: 438 times
ONLY fixed issue "smooth seconds" by change to use type 2 ( Because Type4 not work on last FW )Wahwah wrote: 02 May 2026, 00:07Hi, would someone kindly fix the flickering seconds pointer of this watchface?
viewtopic.php?p=18676#p18676
