Flickering seconds pointer
Has thanked: 114 times
Hi, would someone kindly fix the flickering seconds pointer of this watchface?
And if it is not too much work reducing the size of the data and all three pointers would be appreciated
viewtopic.php?t=4334
Has thanked: 436 times
Been thanked: 2137 times
Wahwah wrote: 02 May 2026, 00:07
ONLY fixed issue "smooth seconds" by change to use type 2 ( Because Type4 not work on last FW )
viewtopic.php?p=18676#p18676
Thank you sir
