How to Publish a Programmatically Developed Watchface
Questions about the main site. Authorship questions.
Moderator: Internal error
guilhermealexs
Post by guilhermealexs »
I created a watchface programmatically. What I currently have is a .zab file, which is generated afterwards with zeus build. However, when I try to upload it to the site, the only allowed extension for upload is .zip. What exactly should be inside this zip file? How can I publish a watchface that was developed programmatically?
Been thanked: 2120 times
guilhermealexs wrote: 04 Feb 2026, 11:24
Inside the .zab file is compressed same as zip file. You can use WinRAR for UpCompress. It will contain app-side.zip and device.zip.
Rename device.zip to your desired watch face name, for example,
yourwatchface.zip, and then upload that file to this website.
Return to “amazfitwatchfaces.com site/catalog”
