How to Publish a Programmatically Developed Watchface
Moderator: Internal error
guilhermealexs
I created a watchface programmatically. What I currently have is a .zab file, which is generated afterwards with zeus build. However, when I try to upload it to the site, the only allowed extension for upload is .zip. What exactly should be inside this zip file? How can I publish a watchface that was developed programmatically?
- Has thanked: 421 times
- Been thanked: 2126 times
Inside the .zab file is compressed same as zip file. You can use WinRAR for UpCompress. It will contain app-side.zip and device.zip.guilhermealexs wrote: 04 Feb 2026, 11:24I created a watchface programmatically. What I currently have is a .zab file, which is generated afterwards with zeus build. However, when I try to upload it to the site, the only allowed extension for upload is .zip. What exactly should be inside this zip file? How can I publish a watchface that was developed programmatically?
Rename device.zip to your desired watch face name, for example,
yourwatchface.zip, and then upload that file to this website.
