Watchface Creation Request [Balance2]
battista
Post by battista »
Hi, could anyone please help me to convert this watchface to Amazfit Balance 2? I found it on T-Rex 3. Thank you very much in advance
https://amazfitwatchfaces.com/t-rex/view/14493
Has thanked: 405 times
Been thanked: 2025 times
battista wrote: 28 Nov 2025, 18:12
As far as I know, you can install this watchface via QR code, because Trex-3 watchface can be used with Balance, Balance2 which have 480x480 screen, no conversion required.
Unless there is a widget that is specific to Trex3, that widget will not show up on other devices, but the watch face you mentioned should work with Balance2 directly.
Has thanked: 123 times
Been thanked: 19 times
Post by taw_bip »
Yes, in my experience, even if the resolution is not the same, I've been able to install watchfaces for other models.
