TSWF04 Garmin on T-Rex 3
Ricardo.cz
- Has thanked: 10 times
- Been thanked: 9 times
- Has thanked: 419 times
- Been thanked: 2115 times
This watchface has some widget that are different from the original.
Top image progress is Humidity. Top image progress is sunrise , sunset
QR Code :
viewtopic.php?p=21699#p21699
MarioLie
- Has thanked: 50 times
- Been thanked: 32 times
Here is your dream look.
- Attachments
cz_T_Rex_2.zip- (244.3 KiB) Downloaded 107 times
cz_Trex_3_PRO_48mm.zip- (180.24 KiB) Downloaded 140 times
cz_T_REX_3.zip- (180.4 KiB) Downloaded 120 times
Ricardo.cz
danielmartis
- Has thanked: 3 times
- Been thanked: 2 times
danielmartis
You simply download the file you need,
then upload it to this website using your ID, and you can install it via the QR code that the website generates for you.
https://amazfitwatchfaces.com/upload
Or try this QR code. The file in this QR code is located at https://catbox.moe/. In some countries, it may not be accessible, or the website may be unavailable at certain times. Therefore, if you cannot install it, you will need to upload it yourself as previously instructed.
