TSWF04 Garmin on T-Rex 3
Ricardo.cz
Has thanked: 11 times
Been thanked: 9 times
Post by Ricardo.cz »
Could you please make this watch face on trex3? Thank you
Has thanked: 425 times
Been thanked: 2131 times
Ricardo.cz wrote: 24 Nov 2025, 17:26
This watchface has some widget that are different from the original.
Image.Image
Top image progress is Humidity.
TSWF04_Trex3.zip
(231.49 KiB) Downloaded 101 times
Top image progress is sunrise , sunset
TSWF04_Trex3_S.zip
(231.49 KiB) Downloaded 135 times
QR Code :
viewtopic.php?p=21699#p21699
MarioLie
Has thanked: 53 times
Been thanked: 37 times
Post by MarioLie »
Here is your dream look.
cz_T_Rex_2.zip
(244.3 KiB) Downloaded 111 times
cz_Trex_3_PRO_48mm.zip
(180.24 KiB) Downloaded 144 times
cz_T_REX_3.zip
(180.4 KiB) Downloaded 125 times
Ricardo.cz
thank you very much great work. all your versions are great 👍😉
danielmartis
Post by danielmartis »
Ahoj , prosím ťa urobil by si ho na T Rex 2 alebo Gtr3?
danielmartis
Ďakujem 👍
Angel@
Post by Angel@ »
Hola es posible hacer el QR de la esfera
Angel@ wrote: 02 Feb 2026, 13:13
You simply download the file you need,
then upload it to this website using your ID, and you can install it via the QR code that the website generates for you.
https://amazfitwatchfaces.com/upload
Or try this QR code.
QR Code
TSWF04TREX3:
TSWF04TREX3_S:
The file in this QR code is located at https://catbox.moe/. In some countries, it may not be accessible, or the website may be unavailable at certain times. Therefore, if you cannot install it, you will need to upload it yourself as previously instructed.
Angel@
Post by Angel@ »
thank you so much asoo
