i put a lot of time making watchfaces,
How can i encrypt them so cant edit them up.
Thanks.
How to encrypt Watchfaces?
- Has thanked: 419 times
- Been thanked: 2109 times
If you're referring to the ZeppOS-based watch face, you can encrypt the script, but not the image.grex69 wrote: 06 Nov 2025, 15:14i put a lot of time making watchfaces,
Thanks.
You can encrypt the script (index.js) in several ways. For example, you can build with Zeus (Zeus is Zepp's official tool). When you "build" (pack) with Zeus, your index.js file is immediately encrypted as .bin. However, you must understand how to write scripts using Zeus to build correctly. You can find more information at the link below:
https://docs.zepp.com/docs/guides/tools ... light=zeus
Or, you can encrypt your script (index.js) using "Uglify."
This encoding method offers a variety of options, allowing you to choose the encoding you prefer. However, Excessive coding can also prevent the clock from working properly.
The option I've used and it works on ZeppOS is:
uglifyjs index.js -m -o index.jshttps://github.com/mishoo/UglifyJS
Users browsing this forum: No registered users and 25 guests
