https://amazfitwatchfaces.com/gts/view/6684
i would try this myself but I cannot open bin file in sashas editor to convert it
Convert request from GTS2 to GTS3
- Kurtyyyyyy
- Has thanked: 6 times
- Been thanked: 2 times
- Has thanked: 404 times
- Been thanked: 2024 times
GTS2 and GTS3 use different OSes, so if you want to edit them, you'll need different editors. Sasha has already done this for both versions. You can find it on the "watch tool" forum at viewforum.php?f=29.Kurtyyyyyy wrote: 04 Oct 2025, 08:35https://amazfitwatchfaces.com/gts/view/6684
As for converting GTS2 to GTS3, as far as I know, there's no program that can directly convert. You have to unpack GTS2 with a GTS2 editor to get the image resources and re-create them using the GTS3 editor.
Here's an example of a conversion.
- Kurtyyyyyy
