How to install watch face on active 2r ?
Topics about Amazfit GT series watches and all the questions regarding their use, etc.
kawumm
Post by kawumm »
The AmazFaces App can't find my watch. How can I install a watch face manually?
Been thanked: 2121 times
kawumm wrote: 08 Aug 2025, 09:14
Please try to see this :
Hope it is useful for you.
kawumm
Post by kawumm »
Thx
pak0roid
Post by pak0roid »
Is there any update on this issue regarding the connection with the Active 2 (Round)? I have Amazfaces version 4.7.397 (running on iOS) and cannot establish the Bluetooth connection. I tried on different iOS devices and strategies, and no luck. No problem using Amazfaces with my BIP 6. I will try generating a QR code, but for custom watchfaces (using the Watch Face Editor - SashaCX75), it seems to be quite difficult to make it work (lots of added steps to create and post the custom QR code).
asoo wrote: 08 Aug 2025, 10:00
Has thanked: 1161 times
Been thanked: 278 times
pak0roid wrote: 27 Aug 2025, 20:41
The latest iOS version of AmazFaces is 4.7.400, so please make sure you’re updated to that build.
For the Active 2 (Round) and also the Bip 6, installation via QR code works fine directly in the app. In the Downloads section you can add your own watch face and then install it through the generated QR — no extra manual steps are needed.
Return to “Device discussion”
