How to install watch face on active 2r ?
The AmazFaces App can't find my watch. How can I install a watch face manually?
- Has thanked: 421 times
- Been thanked: 2129 times
Please try to see this :kawumm wrote: 08 Aug 2025, 09:14The AmazFaces App can't find my watch. How can I install a watch face manually?
Hope it is useful for you.
Is there any update on this issue regarding the connection with the Active 2 (Round)? I have Amazfaces version 4.7.397 (running on iOS) and cannot establish the Bluetooth connection. I tried on different iOS devices and strategies, and no luck. No problem using Amazfaces with my BIP 6. I will try generating a QR code, but for custom watchfaces (using the Watch Face Editor - SashaCX75), it seems to be quite difficult to make it work (lots of added steps to create and post the custom QR code).
asoo wrote: 08 Aug 2025, 10:00Please try to see this :kawumm wrote: 08 Aug 2025, 09:14The AmazFaces App can't find my watch. How can I install a watch face manually?
- GIK-Team
- root
- Has thanked: 1165 times
- Been thanked: 279 times
The latest iOS version of AmazFaces is 4.7.400, so please make sure you’re updated to that build.pak0roid wrote: 27 Aug 2025, 20:41Is there any update on this issue regarding the connection with the Active 2 (Round)? I have Amazfaces version 4.7.397 (running on iOS) and cannot establish the Bluetooth connection. I tried on different iOS devices and strategies, and no luck. No problem using Amazfaces with my BIP 6. I will try generating a QR code, but for custom watchfaces (using the Watch Face Editor - SashaCX75), it seems to be quite difficult to make it work (lots of added steps to create and post the custom QR code).
For the Active 2 (Round) and also the Bip 6, installation via QR code works fine directly in the app. In the Downloads section you can add your own watch face and then install it through the generated QR — no extra manual steps are needed.
