conversion a gtr 3
- Has thanked: 419 times
- Been thanked: 2109 times
I would suggest you also mention where the watchface you are referring to comes from, or if possible post a link to where the watchface came from, or at least the name of the dial.
cierto perdón este es el enlace original y su autor es Lattennaller https://amazfitwatchfaces.com/balance/view/3308
I made it for my own use. If you are interested, you can check it out here.Picajets wrote: 21 Feb 2025, 16:41cierto perdón este es el enlace original y su autor es Lattennaller https://amazfitwatchfaces.com/balance/view/3308
Hi again, the second hand doesn't work, it's completely stopped. Is it my fault or does it happen to someone else? Thanks again.
Lattenknaller
- Has thanked: 60 times
- Been thanked: 133 times
Lattenknaller wrote: 22 Feb 2025, 11:50In my original, there are no second hand. Only digital seconds.
If you mean the circle below, it's not seconds, it's a power pointer.Picajets wrote: 22 Feb 2025, 11:00Hi again, the second hand doesn't work, it's completely stopped. Is it my fault or does it happen to someone else? Thanks again.
