conversion a gtr 3
Picajets
conversion a gtr 3
Post by Picajets »
Hi everyone, could someone convert this nice sphere to the GTR 3 model? Thanks in advance.
Has thanked: 415 times
Been thanked: 2075 times
Picajets wrote: 21 Feb 2025, 16:26
I would suggest you also mention where the watchface you are referring to comes from, or if possible post a link to where the watchface came from, or at least the name of the dial.
Picajets
Post by Picajets »
cierto perdón este es el enlace original y su autor es Lattennaller https://amazfitwatchfaces.com/balance/view/3308
romstemp
Has thanked: 9 times
Been thanked: 41 times
Post by romstemp »
Picajets wrote: 21 Feb 2025, 16:41
I made it for my own use. If you are interested, you can check it out here.
https://amazfitwatchfaces.com/gtr/view/42413
Picajets
Post by Picajets »
Muchas gracias
Picajets
Post by Picajets »
Hi again, the second hand doesn't work, it's completely stopped. Is it my fault or does it happen to someone else? Thanks again.
Lattenknaller
Has thanked: 60 times
Been thanked: 132 times
Post by Lattenknaller »
In my original, there are no second hand. Only digital seconds.
romstemp
Post by romstemp »
Lattenknaller wrote: 22 Feb 2025, 11:50
Picajets wrote: 22 Feb 2025, 11:00
If you mean the circle below, it's not seconds, it's a power pointer.
Picajets
Post by Picajets »
Ahhh ok gracias a los dos
