I've looked through the forum but cannot find answer. I have a Mi Band 9. I've created a very rudimentary watchface in Watch Face Maker and exported it. Got a ZAB file. Extracted it and did not get BIN file (which is what I need). I read on the forum that you need to select 'non zepp os' in creator, but this limits resolutions and Mi Band 9 is not present. Any help would be appreciated.
How to convert ZAB to BIN for Mi Band 9?
- Has thanked: 411 times
- Been thanked: 2050 times
I'm not sure if I understand correctly
You use Zepp's Watch Face Maker to create a watch face and you want to apply it to the mi band 9 ?????
As far as I know, it is unlikely to work and there is no convert
Because the mi band 9 has a different structure and command set than the zepp product
Although the zepp non-zeppOS devices have a BIN extension, the system structure is not the same as the mi band 9
So I think if you want to create a watch face for the MI band, you can look at the related topics like
viewtopic.php?t=4324
