Resources to create Watchfaces?
Hi! I bought an Amazfit Band 7 a couple days ago and I want to costumize it but when i use the watchface maker i don't have the resources (like the style of digital time, weather, calories, etc) and i would like to know if there's any resource package to create the Watchfaces easily! Thanks in advance!
- Has thanked: 420 times
- Been thanked: 2120 times
All resources are images, you have to create them from scratchTomynsdk wrote: 03 Aug 2024, 18:11Hi! I bought an Amazfit Band 7 a couple days ago and I want to costumize it but when i use the watchface maker i don't have the resources (like the style of digital time, weather, calories, etc) and i would like to know if there's any resource package to create the Watchfaces easily! Thanks in advance!
Or the easiest way is you can select resources from the existing watchface in this web and then unpack and bring resource image to make your watchface
And you can create images of numbers, days, months, years from TTF fonts, you can create them through the web at the link below
Thanks for the answer! It's actually quite difficult.
I wanted to install a Pipboy watchface that i loved a lot, but i can't download the AmazFaces app because is not available on my Moto g60s and i don't know how to install that watchface any other way
I read about some qr codes, but i think that's only for self-created watchfaces.
Anyway, i'll keep trying! Thanks!
Moto g60s it use android OS, why you can not Download and install App AmazFaces ??????
I think you should be able to install App AmazFast via Google Play.
https://play.google.com/store/search?q= ... apps&hl=en
- Has thanked: 130 times
- Been thanked: 19 times
Another option is the Facemaker application. It has a library that can get you started with different hands, backgrounds, etc. It also has a vector drawing tool. The author has several tutorials on YouTube:
https://www.youtube.com/@FacemakerNunoBessa/videos
Thank you for the suggestion! I'll give Facemaker a try. It sounds like it has all the resources I need to get started, plus the tutorials on YouTube will definitely help! Hopefully, this app works better for me than the AmazFaces one. By the way, I came across a handy qr codetaw_bip wrote: 03 Aug 2024, 20:06Another option is the Facemaker application. It has a library that can get you started with different hands, backgrounds, etc. It also has a vector drawing tool. The author has several tutorials on YouTube:
recently that might be useful for customizing some watchfaces. I'll check out Facemaker right away!
u6gljnuj4l
I’ve had similar problems with customizing watchfaces. You can use tools like Photoshop or free editors to design icons for time and weather. If AmazFaces doesn’t work, Facemaker is a good option with helpful tutorials. You can also try extracting resources from existing watchfaces using mmk.pw/font_extract. Hope this helps,
