Question Working 2 dots in digital clock ( aka " : " )
Hi guys, this question is related to the usage of ticking (???) dots on digital time, you know (e.g: 12 : 32) those two dots in between hour and minutes.
I cant figure it out how to make it work with the editor (sasha's v11)
always got an weird behavior, 10 seconds on, 10 seconds off...
BTW, I've made x10 png's to work in a row (on/off) but clearly Im doing it wrong.
Any clues?
Any clues?
- Has thanked: 420 times
- Been thanked: 2120 times
It is recommended to upload your sample work. Where you found the problem would be very helpful. For those who want to help you for use in answering questionsAWfan wrote: 17 Jul 2024, 00:08Hi guys, this question is related to the usage of ticking (???) dots on digital time, you know (e.g: 12 : 32) those two dots in between hour and minutes.
Any clues?
If you want to make " : " blink in Digital, you can do it in several ways.
But the way I recommend is to use "animation frame" to do it. By creating 6 images (because the animation will work correctly if there are more than 5 images)
Hi #asoo, thanks for the reply.asoo wrote: 17 Jul 2024, 07:06It is recommended to upload your sample work. Where you found the problem would be very helpful. For those who want to help you for use in answering questions
I tried as you suggested, with 6 images (i also did it with 8 and 10), but something seems wrong, every time the animation starts makes some micro stop after blinking 2 times > micro pause > blink 2 times again, this happens with 6 images. With 10 images same behaviour but 4 times blink, then micro pause and resume, all over again.
Weird...
I dont know if you have an GTR 4 to test (in editor looks smooth, no "pauses")
I'll gladly share the file.
- Attachments
TTMMBRN_mod_.zip- (325.03 KiB) Downloaded 77 times
I'm not sure about the problem either. I don't have a GTR4.AWfan wrote: 17 Jul 2024, 21:45Hi #asoo, thanks for the reply.
Weird...
But as far as installing your watch face on my " Amazfit Balance", I didn't found the issue you reported. I tried turning it on for 5 minutes and the dot flashed continuously without stopping or freezing at all.
Oh wow... thats strange indeed.asoo wrote: 17 Jul 2024, 22:38I'm not sure about the problem either. I don't have a GTR4.
It should be as easy as 1 image on - 1 image off, on an infinite loop, I dont get it.
I will try to upload a short video to show off how it looks on my watch, but certainly it is.
Thanks for testing, i'll let you know when the video is online.
AWfan wrote: 17 Jul 2024, 22:51
If you're having trouble with the animation, you might try using the image from Seconds to create blinking dots. By specifying that the tens digit be in the x-axis direction, have a negative value (outside the screen boundary) and specify the space between Tens and Units place Make it wide enough so that the back of the unit is where the flashing dot is.
Example:
Alright, will give it a shot to that approach.asoo wrote: 17 Jul 2024, 22:52If you're having trouble with the animation, you might try using the image from Seconds to create blinking dots. By specifying that the tens digit be in the x-axis direction, have a negative value (outside the screen boundary) and specify the space between Tens and Units place Make it wide enough so that the back of the unit is where the flashing dot is.
Example:
TTMMBRN_mod_noAnimation.zip
In the meanwhile here is the video, hope you can notice the micro-gap between the 2 blinks.
https://streamable.com/vnksal
In Balance, continuous blinking normally.AWfan wrote: 17 Jul 2024, 23:02
Reporting here, your 2nd method (tricky as f*ck, to say the truth
Now is blinking flawlessly, you are a genious my men!!!
Thanks for your time and dedication (as usuals).
Till next time!
Cheers.
