Problem installing Watch Face on Amazfit Balance
schwaitz
Post by schwaitz »
I have an Amazfit Balance and I'm having trouble downloading watchfaces. When I click on the "show QR on watch" option, it appears that the file has been downloaded, but when I open the Zepp application, click on developer options, then scan and open the gallery, there is no file there, and all the Permissions have been given on Android to both the Amazfaces app and the Zepp app. Could you make a more detailed tutorial on how to install to find out the problem??
Has thanked: 1150 times
Been thanked: 277 times
schwaitz wrote: 30 Jun 2024, 17:57
schwaitz
Post by schwaitz »
The problem is after the installation of QR list. It´s not clear, and even I putting the URL code nothing happens
schwaitz wrote: 30 Jun 2024, 20:40
1. https://docs.zepp.com/docs/guides/tools/zepp-app/
2. Download QR List app
3. Copy and past URL ID into the QR List app
4. Press "Show QR on the watch" button
schwaitz
Post by schwaitz »
The explanation it´s not clear. When I choose the watch face in the app and click on " show QR on the watch ", I wait the advertisement, than nothing happens, there is no QR code appearing at the watch. The old way to sinchronize , as amazfit GTR 4 is much better
schwaitz
Post by schwaitz »
When I click at developer mode, than scan, there is no watchface stored
TONYRM
Post by TONYRM »
Amazfit balance + Samsung s23 Plus
I can't see the QR code
I have given all permissions activated developer mode
If I send the file to qrcode on balance I don't see it and I don't even see the url to copy
Where am I wrong
Sorry my bad English
Has thanked: 130 times
Been thanked: 19 times
Post by taw_bip »
I use the Notify for Amazfit & Zepp app for Android to install custom watchfaces I download to my phone. Might want to try that.
TONYRM wrote: 06 Nov 2024, 14:01
Where am I wrong
Hai letto le istruzioni mostrate dall’app? Troverai tutti i passaggi spiegati passo dopo passo. Prova a seguire la guida e, se riscontri ancora problemi, faccelo sapere!
TONYRM
Post by TONYRM »
GIK-Team wrote: 06 Nov 2024, 20:12
Where am I wrong
Grazie della risposta
Ho seguito la guida, il balance è connesso al telefono
-Attivato la modalità sviluppatore
-Messo visibile in zepp il balance
-dato i permessi
-Scaricato Qrcode
Nulla ...quando invio il qrcode al balance non lo vedo e non vedo neanche url da app AW
Come posso verificare se AW si connette a zeep o al Balance?
Grazie
TONYRM wrote: 07 Nov 2024, 09:06
-dato i permessi
-Scaricato Qrcode
Grazie
Ecco l’istruzione completa:
  1. Abilita la modalità sviluppatore (dev mode) su Zepp: Link alla guida.
  2. Scarica l’app QR List dal Zepp App Store.
  3. Copia l’URL ID (passaggio 2 dell’istruzione mostrata nella nostra app durante il download del quadrante) e incollalo nell’app QR List.
  4. Apri QR List sull’orologio e scansiona il QR con l’app Zepp in modalità sviluppatore.
Fammi sapere se riscontri ancora problemi!
TONYRM
Post by TONYRM »
GIK-Team wrote: 07 Nov 2024, 09:35
-dato i permessi
-Scaricato Qrcode
Grazie
Ho letto le istruzioni..
Ho seguito la guida passo per passo
Nella applicazione non vedo url e non riesco a copiare url
Non riesco ad inviare qrcode al Balance
Da pc funziona se leggo il qrcode
Da Telefono non funziona
TONYRM wrote: 07 Nov 2024, 13:50
Come puoi vedere, nella zona evidenziata sullo screenshot, basta cliccare lì per copiare l’URL. Una volta copiato, puoi incollarlo nell’app QR List e procedere con l’installazione. Facci sapere se funziona!
TONYRM
Post by TONYRM »
GIK-Team wrote: 07 Nov 2024, 18:49
Veramente Grazie...grazie
Alla fine ci sono riuscito...
Per me era uno spoiler uguale per tutte le whatchface...credevo fossero solo le istruzioni d'uso... :D
Ti ringrazio ancora...
TONYRM wrote: 07 Nov 2024, 22:02
Siamo lieti che alla fine tu ci sia riuscito! 😊 Grazie per il tuo feedback – stiamo lavorando per rendere il tutto più intuitivo e facile da usare.
Alfred2021
Post by Alfred2021 »
Ciao a Tutti. Non vedo qr list da Amazfit app store
Alfred2021 wrote: 19 Nov 2024, 11:56
Per quale modello di orologio stai cercando l’app QR List?
Alfred2021
Amazfit balance
Ilducatone
Post by Ilducatone »
Buongiorno,
su QR list non riesco ad inserire nessun URL ID.
Ho seguito tutte le istruzioni ma niente
Ilducatone wrote: 02 Dec 2024, 14:47
Buongiorno,
Mi dispiace per i problemi che stai incontrando con l’inserimento degli URL ID su QR list. Per aiutarti al meglio, potresti specificare esattamente cosa succede quando provi ad inserire un URL? Ricevi qualche messaggio di errore? Queste informazioni ci aiuteranno a comprendere meglio il problema e a fornirti una soluzione più precisa.
seat600
Post by seat600 »
Tengo un Amazfit Balance y en la tienda de aplicaciones de la aplicación Zeep no aparece ninguna apk que se llame QR list, si que aparece una llama QR Card 3.
seat600 wrote: 02 Dec 2024, 20:41
Para utilizar correctamente la funcionalidad QR Card en tu Amazfit Balance, necesitas actualizar nuestra aplicación a la última versión beta disponible. Asegúrate de instalar esta versión beta para acceder a todas las nuevas características, incluida la QR Card.
seat600
Post by seat600 »
Muchas gracias. Cómo actualizo a la última versión beta?
seat600
Post by seat600 »
He actualizado a la versión Beta de amazfit watch faces y no me aparece por ningún lado en la store de zepp QR list
seat600
Post by seat600 »
Ahora no se llama QR List, se llama: QR Code.
