Hello there! Could somebody please assist with converting this watch face to be compatible with the Amazfit GTS 4 Mini?
https://amazfitwatchfaces.com/gts/view/8395
Convert request for Amazfit GTS 4 Mini!
- Has thanked: 417 times
- Been thanked: 2090 times
Because p i p b o y has copyright.Ny666 wrote: 21 May 2024, 16:31Hello there! Could somebody please assist with converting this watch face to be compatible with the Amazfit GTS 4 Mini?
If I remember correctly, there was a complaint from the copyright owner, p i p b o y, regarding copyright infringement by using his work. published without permission, So that is reason that the link you attached is a private link.
They are not displayed on the web page. The only access is through a direct link.
In order not to cause trouble to the web, therefore, if this watch face, once the conversion is complete, may not be posted in this Topic.
Please check your PM. ( Private Messages )
Thank you so much, that makes sense
I appreciate you taking the time to do this!
