Convert request for Amazfit GTS 4 Mini!
Ny666
Post by Ny666 »
Hello there! Could somebody please assist with converting this watch face to be compatible with the Amazfit GTS 4 Mini?
https://amazfitwatchfaces.com/gts/view/8395
Been thanked: 2090 times
Ny666 wrote: 21 May 2024, 16:31
Because p i p b o y has copyright.
If I remember correctly, there was a complaint from the copyright owner, p i p b o y, regarding copyright infringement by using his work. published without permission, So that is reason that the link you attached is a private link.
They are not displayed on the web page. The only access is through a direct link.
In order not to cause trouble to the web, therefore, if this watch face, once the conversion is complete, may not be posted in this Topic.
Please check your PM. ( Private Messages )
Ny666
Post by Ny666 »
Thank you so much, that makes sense :) I appreciate you taking the time to do this!
