Request WF conversion for [Trex 2]
JimmyAle
Post by JimmyAle »
Could some creators port this beautifull WF to Trex 2?
I tried to convert it using "convert" function in the WF editor 10.3, but i've found the rotating compass not working.
Tnx a lot :)
https://amazfitwatchfaces.com/balance/v ... b510fad558
Has thanked: 429 times
Been thanked: 2132 times
I'm not sure if the Trex-2 can display compass on the dial.
ADV02_T_Rex_2.zip
(464.95 KiB) Downloaded 108 times
But this watch face has been converted to a size of 454x454 (Trex2 screen size).
With sasha's editor 10.3 and edit "custom script about compass" to have x,y orientation suitable for 454x454.
But as mentioned initially I'm not sure if it will work on Trex2 or not because I do not have trex2 to test.
But as far as testing with "Balance" using ZeppOS 3.5 can work normally.
Has thanked: 132 times
Been thanked: 21 times
Post by taw_bip »
This works on the TRex2 but you have to run the compass calibration first.
I was able to install the Balance version and it's working. The watchface is a little large for the T-Rex 2 screen so part of it is off screen but it's interesting to test.
JimmyAle
Post by JimmyAle »
It’s perfect!!!!!
Now the compass works very well!
Tnx a lot
