Port for GTR 4
mrbutthead
- Has thanked: 60 times
- Been thanked: 5 times
Port for GTR 4
Hello. Please port this WF for GTR 4.
https://play.google.com/store/apps/deta ... ign.stylez
- Has thanked: 430 times
- Been thanked: 2132 times
Understand before downloadingmrbutthead wrote: 25 Feb 2024, 23:44Spoiler
- This watchface not function change color
- This watchface have functions change Element steps, distance, calories, heart rate by click on icon steps, distance, calories, heart rate
This watch face can be unpacked with Sasha's editor.
mrbutthead
mrbutthead
You can convert by Sasha's editor
mrbutthead
Which editor version do you use to convert? I tested it using editor Version 10.3 and it can convert to GTR4 correctly.
This file downloaded from web and converted with editor 10.3. Tested on simulator. Can change colors like Amazfit Balance version.
Download :
viewtopic.php?p=17631#p17631
mrbutthead
I also use this version, the conversion works fine, but the color on the watch does not change
mrbutthead
I think the function I used in the script can be used with any version of zeppOS. If you can't change the color, I can't make any changes either because I don't have a GTR4 to test.mrbutthead wrote: 27 Feb 2024, 17:21I also use this version, the conversion works fine, but the color on the watch does not change
I tested with Balance ZeppOS 3.5 and it worked normally.
I didn't edit anything further, I just downloaded it from the web and converted it.
It's the same file that's on the web.
