Port for GTR 4
mrbutthead
Has thanked: 60 times
Port for GTR 4
Post by mrbutthead »
Hello. Please port this WF for GTR 4.
https://play.google.com/store/apps/deta ... ign.stylez
Has thanked: 405 times
Been thanked: 2028 times
mrbutthead wrote: 25 Feb 2024, 23:44
- This watchface not function change color
- This watchface have functions change Element steps, distance, calories, heart rate by click on icon steps, distance, calories, heart rate
This watch face can be unpacked with Sasha's editor.
This file downloaded from web and converted with editor 10.3. Tested on simulator. Can change colors like Amazfit Balance version.
69D_STYLEZ_digital_GTR_4_B.zip
(636.03 KiB) Downloaded 111 times
mrbutthead
@asoo awesome, thanks
mrbutthead
@asoo Can I have a balance version with changing colors?
mrbutthead wrote: 27 Feb 2024, 15:10
You can convert by Sasha's editor
mrbutthead
@asoo I tried converting, the color doesn't change for me
mrbutthead wrote: 27 Feb 2024, 16:31
Which editor version do you use to convert? I tested it using editor Version 10.3 and it can convert to GTR4 correctly.
Download :
viewtopic.php?p=17631#p17631
mrbutthead
I also use this version, the conversion works fine, but the color on the watch does not change
mrbutthead
@asoo your version works great. Thank you very much
mrbutthead wrote: 27 Feb 2024, 17:21
I think the function I used in the script can be used with any version of zeppOS. If you can't change the color, I can't make any changes either because I don't have a GTR4 to test.
I tested with Balance ZeppOS 3.5 and it worked normally.
mrbutthead wrote: 27 Feb 2024, 17:24
I didn't edit anything further, I just downloaded it from the web and converted it.
It's the same file that's on the web.
