Convert for GTR 4
mrbutthead
Has thanked: 60 times
Convert for GTR 4
Post by mrbutthead »
Hello, please convert this WF for GTR 4.
https://amazfitwatchfaces.com/gtr/view/35180
Has thanked: 436 times
Been thanked: 2137 times
mrbutthead wrote: 02 Feb 2024, 10:12
Fixed Topmain :
RZ282_CS_GTR4.zip
(353.88 KiB) Downloaded 109 times
Test on simulator
mrbutthead
@asoo Thanks, man
mrbutthead
@asoo Little problem) https://postimg.cc/QBb4bS0N
mrbutthead wrote: 02 Feb 2024, 11:59
@mrbutthead
sorry I forget decode image please Download again.
mrbutthead
@asoo The color is slightly coming out around the circle, can this be fixed?
mrbutthead wrote: 06 Aug 2024, 11:22
It is possible to fix it, just make topmain.png an image with black color filling the frame.
But I can't verify the result of the fix properly because I don't have GTR4 to test it.
Here is the modified topmain.png.
Most of the problems you asked about are caused by conversion. In the conversion, the program will calculate to reduce or increase the size of the image. And there will be a rounding of decimal points. The size of the image may not fit. So in some cases, after converting, you have to edit the image a little to fit your device. Since I only have Balance, I can't test it to fit other devices. It is up to the user to test and fix it by themselves.
Although the simulator can simulate, but in some cases, there are still issue to show not like on the real device.
This file is normal PNG :
Topmain.rar
(63.25 KiB) Downloaded 85 times
Test on Simulator :
mrbutthead
@asoo Thank you, everything is fine now
