Convert for GTR 4
mrbutthead
- Has thanked: 60 times
- Been thanked: 5 times
- Has thanked: 429 times
- Been thanked: 2132 times
Fixed Topmain :
Test on simulator
mrbutthead
mrbutthead
@mrbutthead
sorry I forget decode image please Download again.
mrbutthead
It is possible to fix it, just make topmain.png an image with black color filling the frame.
But I can't verify the result of the fix properly because I don't have GTR4 to test it.
Here is the modified topmain.png.
Most of the problems you asked about are caused by conversion. In the conversion, the program will calculate to reduce or increase the size of the image. And there will be a rounding of decimal points. The size of the image may not fit. So in some cases, after converting, you have to edit the image a little to fit your device. Since I only have Balance, I can't test it to fit other devices. It is up to the user to test and fix it by themselves.
Although the simulator can simulate, but in some cases, there are still issue to show not like on the real device.
This file is normal PNG : Test on Simulator :
mrbutthead
