Kit Black (Lattenknaller)
Has thanked: 205 times
Post by amazfitfacesafrica »
Good morning to all. Can anyone with knowledge convert this watchface for GTR3 Pro because uses ttf font and sasha editor can't convert it properly and i don't have the skills to fix it and convert it myself. Thank you and a big thanks to Lattenknaller for the amazing dials he produce.
https://amazfitwatchfaces.com/balance/view/152
Please only convert it for GTR3 Pro as it is. Thank you.
Has thanked: 405 times
Been thanked: 2028 times
amazfitfacesafrica wrote: 26 Jan 2024, 09:13
It's not just convert, you have to create a new font from scratch.
So I told you earlier. If you want to use watchfaces that create by use TTF on your GTR3pro, you should learn more about how to create them. yourself
To convert TTF to images, you can use this web page to help.
I will help you again Next time, hope you can do it yourself.
Kit_Black_GTR_3_Pro.zip
(265.57 KiB) Downloaded 170 times
Thank you so much for convertion and for font extractor site. I didn't know there was such a site for fonts. If i create the fonts can I add them with the sasha's editor?
amazfitfacesafrica wrote: 26 Jan 2024, 12:11
If the editor can open it, you can simply convert to your device type and change the TTF element to use "Numerical values" element and use the image file you created in the element you changed.
