- Amministratore
Create chart with heart rate
GiovanniJr
- Contatta:
Hello fellows.
I'm new but I want to learn.
Can someone explain to me how to create faces with the graphic - heart rate.
I intend to create for the Amazefit GTR 3.
Thank you very much!
Best Regards
Best Regards
Ultima modifica di GiovanniJr il 11 ago 2023, 12:38, modificato 1 volta in totale.
- Has thanked: 404 times
- Been thanked: 2019 times
As far as i see you didn't specify the device you want to ask, so
I think maybe no one can answer the question for you. It is advisable to specify the device you want to inquire about. You maybe got the right answer.
GiovanniJr
- Contatta:
Is truth! You're absolutely right...
Sorry...
Sorry...
I'm not sure you mean graphic or graph.GiovanniJr ha scritto: 11 ago 2023, 11:44Hello fellows.
Best Regards
If you mean graphic, you probably mean a picture used to show the heart rate zone.
In GTR3 there are 6 images to show different heart rate zones.
If you mean graph ( heart rate graph )
In this section, you need to create a custom script by adding it yourself to the file.
index.js with a text editor
In the editor will not have this section
An example of a dial with a heart rate graph.
Code specific to the part related to the heart rate graph.
Some variable names may not be the same as in the example watchface.
Codice: Seleziona tutto
** Watch_Face_Editor tool
** watchface js version v2.1.1
** Copyright © SashaCX75. All Rights Reserved
try {
//start of ignored block
const __$$app$$__ = __$$hmAppManager$$__.currentApp;
function getApp() {
return __$$app$$__.app;
function getCurrentPage() {
return __$$app$$__.current && __$$app$$__.current.module;
const __$$module$$__ = __$$app$$__.current;
const h = new DeviceRuntimeCore.WidgetFactory(new DeviceRuntimeCore.HmDomApi(__$$app$$__, __$$module$$__));
const {px} = __$$app$$__.__globals__;
const logger = Logger.getLogger('watchface_SashaCX75');
//end of ignored block
//dynamic modify start
let normal_background_bg_img = ''
let normal_g_heart = ''
//dynamic modify end
__$$module$$__.module = DeviceRuntimeCore.WatchFace({
init_view() {
normal_background_bg_img = hmUI.createWidget(hmUI.widget.IMG, {
x: 0,
y: 0,
w: 454,
h: 454,
src: 'main.png',
///////////////////// Show graph heart rate /////////////////////
normal_g_heart=hmUI.createWidget(hmUI.widget.GRADKIENT_POLYLINE,{
x: 50,
y: 100,
w: 350,
h: 100,
line_color:16738816,
line_width:2,
type:hmUI.data_type.HEART,
show_level:hmUI.show_level.ONLY_NORMAL
let heartArr = hmSensor.createSensor(hmSensor.id.HEART).today;
let min_heart = Math.min(...heartArr)
let max_heart = Math.max(...heartArr)
/////////////////////// show value main , max , min /////////////////////////
let heart_num = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 198,
y: 410,
type: hmUI.data_type.HEART,
font_array:["Act_font_0.png","Act_font_1.png","Act_font_2.png","Act_font_3.png","Act_font_4.png","Act_font_5.png","Act_font_6.png","Act_font_7.png","Act_font_8.png","Act_font_9.png"],
h_space: 0,
align_h: hmUI.align.CENTER_H,
padding: false,
isCharacter: true,
invalid_image: "Act_font_0.png",
isCharacter: true,
unit_sc:"bpm.png",
unit_tc: "bpm.png",
unit_en: "bpm.png",
let maxText = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 300,
y: 372,
text: max_heart,
h_space: 2,
align_h: hmUI.align.LEFT,
padding: false,
isCharacter: true,
let minText = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 300,
y: 372,
text: min_heart,
h_space: 2,
padding: false,
isCharacter: true,
////////////////// End /////////////////////////
normal_image_img = hmUI.createWidget(hmUI.widget.IMG, {
x: 202,
y: 196,
src: 'Act_font_1.png',
//////////////////// resume_Call ////////////////////
resume_call: (function () {
var jstime = hmSensor.createSensor(hmSensor.id.TIME);
var is24 = jstime.is24Hour;
if (is24){ normal_image_img.setProperty(hmUI.prop.SRC, "Act_font_1.png");
} else { normal_image_img.setProperty(hmUI.prop.SRC, "Act_font_2.png");
heart_num.setProperty(hmUI.prop.MORE, {
x: 198,
y: 410,
h_space: 2,
padding: false,
isCharacter: true,
unit_sc:"bpm.png",
unit_tc: "bpm.png",
unit_en: "bpm.png",
maxText.setProperty(hmUI.prop.MORE, {
x: 300,
y: 322,
text: max_heart,
h_space: 2,
padding: false,
isCharacter: true,
minText.setProperty(hmUI.prop.MORE, {
x: 300,
y: 372,
text: min_heart,
h_space: 2,
padding: false,
isCharacter: true,
pause_call: (function () {
console.log('ui pause');
onInit() {
logger.log('index page.js on init invoke');
build() {
this.init_view();
logger.log('index page.js on ready invoke');
onDestroy() {
logger.log('index page.js on destroy invoke');
} catch (e) {
console.log('Mini Program Error', e);
e && e.stack && e.stack.split(/\n/).forEach(i => console.log('error stack', i));
GiovanniJr
- Contatta:
Hello.
I wanted to say graph ( heart rate graph ) and that's exactly what I wanted to know. Thank you very much!
I will explore, I still have a lot to learn.
A special thanks to the master asoo!
GiovanniJr
- Contatta:
Hello.
I managed to do what I wanted. Thank you very much!
This face is a copy of an original from Ultra. It will only be to explore the potentialities. The next ones will be my creation.
Best regards
Best regards
