Create chart with heart rate
GiovanniJr
Hello fellows.
I'm new but I want to learn.
Can someone explain to me how to create faces with the graphic - heart rate.
I intend to create for the Amazefit GTR 3.
Thank you very much!
Best Regards
Best Regards
- Has thanked: 415 times
- Been thanked: 2075 times
As far as i see you didn't specify the device you want to ask, so
I think maybe no one can answer the question for you. It is advisable to specify the device you want to inquire about. You maybe got the right answer.
GiovanniJr
Is truth! You're absolutely right...
Sorry...
Sorry...
I'm not sure you mean graphic or graph.GiovanniJr wrote: 11 Aug 2023, 11:44Hello fellows.
Best Regards
If you mean graphic, you probably mean a picture used to show the heart rate zone.
In GTR3 there are 6 images to show different heart rate zones.
If you mean graph ( heart rate graph )
In this section, you need to create a custom script by adding it yourself to the file.
index.js with a text editor
In the editor will not have this section
An example of a dial with a heart rate graph.
Code specific to the part related to the heart rate graph.
Some variable names may not be the same as in the example watchface.
** Watch_Face_Editor tool
** watchface js version v2.1.1
** Copyright © SashaCX75. All Rights Reserved
try {
//start of ignored block
const __$$app$$__ = __$$hmAppManager$$__.currentApp;
function getApp() {
return __$$app$$__.app;
function getCurrentPage() {
return __$$app$$__.current && __$$app$$__.current.module;
const __$$module$$__ = __$$app$$__.current;
const h = new DeviceRuntimeCore.WidgetFactory(new DeviceRuntimeCore.HmDomApi(__$$app$$__, __$$module$$__));
const {px} = __$$app$$__.__globals__;
const logger = Logger.getLogger('watchface_SashaCX75');
//end of ignored block
//dynamic modify start
let normal_background_bg_img = ''
let normal_g_heart = ''
//dynamic modify end
__$$module$$__.module = DeviceRuntimeCore.WatchFace({
init_view() {
normal_background_bg_img = hmUI.createWidget(hmUI.widget.IMG, {
x: 0,
y: 0,
w: 454,
h: 454,
src: 'main.png',
///////////////////// Show graph heart rate /////////////////////
normal_g_heart=hmUI.createWidget(hmUI.widget.GRADKIENT_POLYLINE,{
x: 50,
y: 100,
w: 350,
h: 100,
line_color:16738816,
line_width:2,
type:hmUI.data_type.HEART,
show_level:hmUI.show_level.ONLY_NORMAL
let heartArr = hmSensor.createSensor(hmSensor.id.HEART).today;
let min_heart = Math.min(...heartArr)
let max_heart = Math.max(...heartArr)
/////////////////////// show value main , max , min /////////////////////////
let heart_num = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 198,
y: 410,
type: hmUI.data_type.HEART,
font_array:["Act_font_0.png","Act_font_1.png","Act_font_2.png","Act_font_3.png","Act_font_4.png","Act_font_5.png","Act_font_6.png","Act_font_7.png","Act_font_8.png","Act_font_9.png"],
h_space: 0,
align_h: hmUI.align.CENTER_H,
padding: false,
isCharacter: true,
invalid_image: "Act_font_0.png",
isCharacter: true,
unit_sc:"bpm.png",
unit_tc: "bpm.png",
unit_en: "bpm.png",
let maxText = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 300,
y: 372,
text: max_heart,
h_space: 2,
align_h: hmUI.align.LEFT,
padding: false,
isCharacter: true,
let minText = hmUI.createWidget(hmUI.widget.TEXT_IMG, {
x: 300,
y: 372,
text: min_heart,
h_space: 2,
padding: false,
isCharacter: true,
////////////////// End /////////////////////////
normal_image_img = hmUI.createWidget(hmUI.widget.IMG, {
x: 202,
y: 196,
src: 'Act_font_1.png',
//////////////////// resume_Call ////////////////////
resume_call: (function () {
var jstime = hmSensor.createSensor(hmSensor.id.TIME);
var is24 = jstime.is24Hour;
if (is24){ normal_image_img.setProperty(hmUI.prop.SRC, "Act_font_1.png");
} else { normal_image_img.setProperty(hmUI.prop.SRC, "Act_font_2.png");
heart_num.setProperty(hmUI.prop.MORE, {
x: 198,
y: 410,
h_space: 2,
padding: false,
isCharacter: true,
unit_sc:"bpm.png",
unit_tc: "bpm.png",
unit_en: "bpm.png",
maxText.setProperty(hmUI.prop.MORE, {
x: 300,
y: 322,
text: max_heart,
h_space: 2,
padding: false,
isCharacter: true,
minText.setProperty(hmUI.prop.MORE, {
x: 300,
y: 372,
text: min_heart,
h_space: 2,
padding: false,
isCharacter: true,
pause_call: (function () {
console.log('ui pause');
onInit() {
logger.log('index page.js on init invoke');
build() {
this.init_view();
logger.log('index page.js on ready invoke');
onDestroy() {
logger.log('index page.js on destroy invoke');
} catch (e) {
console.log('Mini Program Error', e);
e && e.stack && e.stack.split(/\n/).forEach(i => console.log('error stack', i));
GiovanniJr
Hello.
I wanted to say graph ( heart rate graph ) and that's exactly what I wanted to know. Thank you very much!
I will explore, I still have a lot to learn.
A special thanks to the master asoo!
GiovanniJr
Hello.
I managed to do what I wanted. Thank you very much!
This face is a copy of an original from Ultra. It will only be to explore the potentialities. The next ones will be my creation.
Best regards
Best regards
