Weather elements disappearing when uploading to GTS 2
PlasmaCD
Post by PlasmaCD »
So I'm currently making a watch face for my GTS 2 using the Zepp watchface maker website.
The background is supposed to change with the weather but when I upload the watch face to my watch, the weather elements disappear and I'm only left with a black backround and the time.
I tried reducing the size of the weather images but it's still not working properly.
I also checked in the Zepp app if the weather was syncronized with my watch and it is.
Here is the watch face preview as shown on the website :
And here is the watch face as shown on the watch :
Any help would be gladly appreciated
-- edit
The weather elements didn't appear because their resolution was the same as the gts 2. I fixed it by making the images 2 px thinner.
Has thanked: 419 times
Been thanked: 2104 times
It is advisable to attach the file you are having problems with so that those who want to help you can easily check the problem.
If guessing the issue
- Your weather picture missing number of icons
- Weather information is not linked between mobile phone and watch.
If you use windows, recommend this editor program.
viewtopic.php?t=1888
It will make it easier for you to review your work.
PlasmaCD
Post by PlasmaCD »
Thank you for your remark, I will attach the files right away
PlasmaCD
Post by PlasmaCD »
I found what was causing the problem : I tried uploading the watch face with smaller weather images and it worked fine
