Reddit:
https://www.reddit.com/r/Starfield/comm ... eld_watch/
GitHub:
https://github.com/omrdemir/AndroidApps/tree/main
As far as I know right now, the end of the "circle progress line" will be a round edge when the progress exceeds 10% of the destination value.amazfitfacesafrica wrote: 08 Jul 2023, 07:30Hello to forum. I saw this watchface and i like it and i deside to make it for GTR3 Pro with the resources provide from asoo but the beginning of the step progress is not circular as in the preview, it's only circular at the end of steps progress like preview and the hour markers are not proportional as in the preview either. What is the reason for this and how can it be fixed? Thank you very much. I attach the GTR3 Pro watchface file.
If there is no shadow then you are not using image from. Starfield_RS.rar to convertamazfitfacesafrica wrote: 08 Jul 2023, 09:02Thank you for explanation for steps progress, for the hour hands i mean there's no shadow in hands like GTR3 preview. If you see the hands is without the shadow in my GTR3 Pro version while your GTR3 version has shadow in hands and you can see in the preview here. Thank you.
I don't use owner I can't allow anything.amazfitfacesafrica wrote: 08 Jul 2023, 13:04Thank you for your help and for the resources. Finally everything it's ok. I attach the file if everyone wants it. If i have your permission I will upload it to the site.
Ok thanks for your answer, I ask you for permission because use your resources not because you are the author.asoo wrote: 09 Jul 2023, 01:58I don't use owner I can't allow anything.amazfitfacesafrica wrote: 08 Jul 2023, 13:04Thank you for your help and for the resources. Finally everything it's ok. I attach the file if everyone wants it. If i have your permission I will upload it to the site.
The owner of the work is
But if you want to upload to the web, please do so at your own responsibility. don't ask me for permission because I don't use the owner and don't give me any credit
You can read what I said about resource in the resource post.amazfitfacesafrica wrote: 09 Jul 2023, 10:59
The problem was caused by my own mistake.Houston96 wrote: 09 Jul 2023, 19:33Asoo, I want to ask why month and day are not showing up? I packed the original and tried to convert - same thing.
You can use only the images to create GTR2 with GTR2's editor.cervo223 wrote: 27 Aug 2023, 19:53Good afternoon
I would like to know if this whatchface can be ported for GTR 2.
I know there is a similar watchface already on the site but this one has much more detail.
I tried to do the conversion but I'm running into difficulties because I'm not familiar with the tool to create whatchfaces. If anyone can guide me I would appreciate it
DarkN1ghtmar3 wrote: 08 Sep 2023, 23:24Can someone please make this for trex2 I have no idea how to do this kind of stuff myself
Installed but the screen is cut off on the bottom because it’s not sized properly I want the month and day to showasoo wrote: 09 Sep 2023, 05:47
viewtopic.php?p=16017#p16017
You should be able to use the dial in this port because if I'm not mistaken TrexUL. and Trex2 have the same screen size 454x454.
Sorry I can't help to check with this part as I don't have a Trex2 to test.DarkN1ghtmar3 wrote: 10 Sep 2023, 01:01Installed but the screen is cut off on the bottom because it’s not sized properly I want the month and day to showasoo wrote: 09 Sep 2023, 05:47
I don't think it can make this watchface on the GTR47mm same as GTR3.powlo wrote: 12 Sep 2023, 18:32Is anyone able to convert the Starfield face to a GTR 47mm?
I'm having real difficulty getting it to work. I've tried multiple different apps from this forum and various .zip files but none of them work on my GTR 47mm. I believe it's 454x454, like the GTR3 but I just can't get any to work/convert.
Would super appreciate some help, if possible, kind people!
