Search found 3 matches
Return
by asoo
07 Jul 2023, 08:35
Jump to forum
Jump to topic
Re: Requesting porting of watchface(Starfield) [GTR 3/Trex2/Ultra]
This watch face is interesting.
I have created the format that I want to use.
but anyway This watch face was created by Starfield, which I'm not sure if he allow modifications for other devices.
So I decided to distribute what I've completed as a resource only.
All resources can be packaged as a ...
by asoo
09 Jul 2023, 11:17
Jump to forum
Jump to topic
Ok thanks for your answer, I ask you for permission because use your resources not because you are the author.
You can read what I said about resource in the resource post.
"Anyone who is interested can bring the resource to pack as a watchface by yourself. ........."
https://amazfitwatchfaces ...
by asoo
10 Jul 2023, 00:24
Jump to forum
Jump to topic
Asoo, I want to ask why month and day are not showing up? I packed the original and tried to convert - same thing.
The problem was caused by my own mistake.
The .json file that I created from the beta made some functions not working properly.
You can fix it by
1. When opening the file, delete ...
