Clean face request for convert watchface [GTR 2e]
wanted7888
Post by wanted7888 »
Hi. I have a big request. Could someone convert this shield from amazfit t rex pro to gtr 2e?
https://amazfitwatchfaces.com/t-rex/view/7589
Name: clear simple digital pl
If possible, I would like the dial a little smaller because the numbers from the hour are huge.
wanted7888
Anyone can help??
Has thanked: 441 times
Been thanked: 2142 times
First, if you want Converting works that posted on this web, I advise you to ask for permission from the owner of the work first.
And that you request, you can use " AmazFit WatchFace editor 2 for Windows " to convert T-rex pro to GTR2 yourself.
viewtopic.php?p=8392#p8392
wanted7888
Hi. I received permission. I managed to convert the shield 1:1, however, I can't do it in such a way as to keep the real dimensions and just to center it.
The point is that I want to center it keeping the same size or convert 1:1 and smaller hours/seconds. Can it be done with this program?
wanted7888 wrote: 04 Jun 2023, 20:51
Yes, the program can definitely convert and is correct.
If you convert correctly, you will get a 1:1 screen.
Font size will be enlarged, centered. correctly according to size main screen
This BIN was receive after valid conversion :
But if you want to reduce the size, hours, minutes, slightly, you need to use a graphic editor to edit the image, or if you want someone to help, you should tell us the exact size you want.
Because "smaller size of (hours/seconds) " each person may be different size. ,therefore, you should specify the exact size in pix so that someone who wants to help you , they can convert it exactly as you want. within once
wanted7888
Thank you for explaining everything and for converting the shield. This is good. When I have more time, then maybe I'll play with it because I see that it's time consuming as I started learning this program
