Clean face request for convert watchface [GTR 2e]
wanted7888
Hi. I have a big request. Could someone convert this shield from amazfit t rex pro to gtr 2e?
https://amazfitwatchfaces.com/t-rex/view/7589
Name: clear simple digital pl
If possible, I would like the dial a little smaller because the numbers from the hour are huge.
wanted7888
- Has thanked: 441 times
First, if you want Converting works that posted on this web, I advise you to ask for permission from the owner of the work first.
And that you request, you can use " AmazFit WatchFace editor 2 for Windows " to convert T-rex pro to GTR2 yourself.
viewtopic.php?p=8392#p8392
wanted7888
Hi. I received permission. I managed to convert the shield 1:1, however, I can't do it in such a way as to keep the real dimensions and just to center it.
The point is that I want to center it keeping the same size or convert 1:1 and smaller hours/seconds. Can it be done with this program?
Yes, the program can definitely convert and is correct.
Font size will be enlarged, centered. correctly according to size main screen
But if you want to reduce the size, hours, minutes, slightly, you need to use a graphic editor to edit the image, or if you want someone to help, you should tell us the exact size you want.
Because "smaller size of (hours/seconds) " each person may be different size. ,therefore, you should specify the exact size in pix so that someone who wants to help you , they can convert it exactly as you want. within once
wanted7888
Thank you for explaining everything and for converting the shield. This is good. When I have more time, then maybe I'll play with it because I see that it's time consuming as I started learning this program
