Missing watch_skin_local
Moderatori: asoo, Watchmens
andrew59it
Messaggio da andrew59it »
Hello
trying to load some watch skin to my Trex pro..... the problem is I don't have the watch_skin_local dir into the com.huami.watch.hmwatchmanager/file dir..... anyway I'm able to syncronize skins from the zepp app ...
I use android12 firmware.... Any solution?
Has thanked: 419 times
Been thanked: 2104 times
Messaggio da asoo »
Because zepp has changed the storage of downloaded files to the part that can not be accessed by normal users.
If you want to search downloaded WF or want to copy your watchface to zepp storage, you need to root your phone first.
Or you can use a third party program to synce the watch face.
such as
viewtopic.php?t=590
https://play.google.com/store/apps/deta ... chfaces.st
or
https://play.google.com/store/apps/deta ... c.amazfit1
andrew59it
Thank you, understood.....
