I created and uploaded a new face https://amazfitwatchfaces.com/t-rex/view/10000 using Sasha's editor v7.3. It installs without any errors and the preview image is displayed properly but the actual face on the watch is simply a blank black screen with a small cluster of white pixels in the top left corner.
Anyone know what I've done wrong?
Watch face doesn't display correctly [T-Rex Pro]
- Has thanked: 419 times
- Been thanked: 2115 times
I can't verify it on the actual Device because I don't have it.puddum wrote: 06 Jul 2022, 22:14I created and uploaded a new face https://amazfitwatchfaces.com/t-rex/view/10000 using Sasha's editor v7.3. It installs without any errors and the preview image is displayed properly but the actual face on the watch is simply a blank black screen with a small cluster of white pixels in the top left corner.
But when check it out, your PNG looks like it's compressed.
which the watch cannot read those image files
This is an example of an uncompressed png.
If you can sync this watchface and watchface can use normal , The problem is probably the format of the PNG you used to create the FW.
lpclean_packed_packed.bin (not work)
The PNG image used to create it should format look like this:
Still getting the same result using lpclean_packed_packed.bin
If I'm not mistaken, in the GTR47mm if the main screen doesn't use the first image file, it doesn't display. But I'm not sure Will it be the same with Trex-Pro as well?
The attached file has changed the main screen to 0001.png.
Please try this WF
