Search found 1 match
- 07 Jul 2022, 14:28
- Jump to forum
- Jump to topic
Re: Watch face doesn't display correctly [T-Rex Pro]
Still getting the same result using lpclean_packed_packed.bin
If I'm not mistaken, in the GTR47mm if the main screen doesn't use the first image file, it doesn't display. But I'm not sure Will it be the same with Trex-Pro as well?
The attached file has changed the main screen to 0001.png ...
