Convert T-Rex Pro watchface to T-Rex
deadfunny
Post by deadfunny »
Hi All,
My question is, how can I convert a T-Rex Pro WF into T-Rex?
Sacgeek
Post by Sacgeek »
I have exactly the same question, however reversing the conversion.
From T-Rex to T-Rex Pro.
Has thanked: 418 times
Been thanked: 2100 times
As far as know in now, there is no program that can convert.
T-Rex to T-Rex Pro or T-Rex Pro to T-Rex
If you want to convert, you need to unpack the file and bring the Resource.
Come to create a new one only.
however There is a program that can convert T-rex to T-Rex pro.
But after conversion, some elements won't work.
And the converted files will not use the format of T-rex pro.
The resulting file will only make the T-rex file work on T-rex pro.
You can found T-rex to T-rex pro in this post :
viewtopic.php?p=8844#p8844
