Convert a watchface from GTR 42mm to GTR2e? Help needed!
carsten_h
Post by carsten_h »
Hello!
Is it possible to convert a watchface from GTR 42mm to a GTR2e watchface?
I tried it with this watchface: https://amazfitwatchfaces.com/gtr/view/19515
I tried to open it with the "AmazFit WatchFace editor 2 for Windows" from here: https://www.dropbox.com/s/qp0ii7dspf91x ... 3.zip?dl=0
But when trying to open both downloaded bin files, there is nothing in the resulting directory. When I open another bin file from a watchface I get all files inside the folder.
Can someone help me?
Has thanked: 437 times
Been thanked: 2141 times
carsten_h wrote: 14 Dec 2021, 11:09
Hello!
Unpacked Benz_20 ( All Resource ) ( GTR42mm)
benz_20.zip
(477.04 KiB) Downloaded 90 times
If you would like to unpack BIN GTR47mm/42mm , you will try "AmazFit WatchFace editor for Windows by SashaCX75"
viewtopic.php?t=1076
After unpack you can bring only images to use on "AmazFit WatchFace editor 2 for Windows"
( json for GTR can not work on GTR2 )
or you can convert GTR42mm to GTR47mm and convert again to GTR2 by use "AmazFit_Watchface_Editor_(GTR47ToGTR2)"
viewtopic.php?p=8844#p8844
But in this selection maybe some element not work.
carsten_h
Post by carsten_h »
asoo wrote: 14 Dec 2021, 11:09
I tried this. It seems the pictures are correctly stretched to 47mm. But If I safe this with this tool and open it with the GTR2 Editor it says that Images with number 0 can not be used and I have only the background.
So this is what you mean that some Element not work.
So I have the images and have to create the watch again by hand I think.
Ok, this is really hard work. I will try.
Thank you!
carsten_h wrote: 14 Dec 2021, 12:18
Thank you!
File conver from "AmazFit_Watchface_Editor_(GTR47ToGTR2)" can not use GTR2 Editor open if you use AmazFit_Watchface_Editor_(GTR47ToGTR2) you must to use it to convert to GTR2 , "BIN" after convert file can use on GTR2 but the format it's still GTR1 ( so can not open on GTR2 editor too )
So as not to be confused if you want to make GTR2 I recommend you to use only images and bring it to built on "AmazFit WatchFace editor 2 for Windows"
- Name of file in GTR2 start at 0001 , Do not forget rename images before use.
- And if possible, recommend 0001 as the background image.
