Is it possible to use GTR watchfaces on GTR 2e?
Thank you
I can see actual display size is exactly the same so it should not be used any modification from GTR to GTR2 right ? Anyone has already tried this out ? I would not want to get unserviceable my new GTR2e on this attempt. I am pretty sure some of you much expert guys has already experienced this.
Any feedback on this regard?
Many thanks
Many thanks
- Has thanked: 411 times
- Been thanked: 2050 times
ฺ"BIN" GTR can not use with GTR2 or GTR2e
But you can convert GTR to GTR2 by use program "AmazFit_Watchface_Editor_(GTR47ToGTR2)"
viewtopic.php?p=8844#p8844
However some elements will not work after converted
Example :
- Can not convert Animation (Because GTR2 no support now)
- Some progress bar not work
- if you use AM PM you must to ADD after convert
- No have custom AOD ( Because BIN after convert still is GTR format )
You can read more in the forum. viewtopic.php?p=8844#p8844
Example :
