GTR47 watchface to GTR2e
GR33ZY
Post by GR33ZY »
I have a GTR47. I'm using the attached watchface.
I would like to replace my GTR47 by a GTR2e but keep using the attached watchface.
It seems that now there are tools to convert GTR47 watchfaces to GTR2e.
The problem is that i'm using a mac and the tools are working on windows.
Can someone please tell me if this watchface can be fully functional on a GTR2e?
and is it possible to get a full AOD of this watchface on a GTR2e?
tag_connected_weather_black (1).bin
(1.96 MiB) Downloaded 131 times
spanking time
Post by spanking time »
What tool converts from the 47mm to GTR 2?
GR33ZY
Post by GR33ZY »
I'm not 100% sure but it seems that this tool should do the job :
viewtopic.php?f=29&t=1888&start=150
Has thanked: 437 times
Been thanked: 2141 times
spanking time wrote: 05 May 2021, 15:18
viewtopic.php?p=8843#p8843
GR33ZY wrote: 05 May 2021, 11:36
Convert GTR to GTR2/2e can not make Full AOD
This Version is GTR2e ( Not convert )
tag_connected_weather_black_GTR2_FullAOD.bin
(473.31 KiB) Downloaded 108 times
PS. Full AOD GTR2/2e can not show seconds hand
GR33ZY
Post by GR33ZY »
Hi, Thanks a lot for your work.
Do you know how can I convert this GTR2e watch to full AOD (without seconds hand)
GR33ZY wrote: 05 May 2021, 16:59
?? You mean this tag_connected_weather_black_GTR2_FullAOD.bin ??
This file is GTR2 100% it's have full AOD . This file not convert from GTR47mm
if you convert from GTR47mm by program GTRtoGTR2 , it's can not make Full AOD so you want full AOD on GTR2 you must create new for GTR2 only
GR33ZY
Post by GR33ZY »
Sorry, I just tried your watchface on the GTR2e. It is perfect with full AOD. Thank you so much for your work
spanking time
asoo wrote: 05 May 2021, 15:39
Hm, doesn't do anything. I used the GTRtoGTR2 program, open a 47mm watch face bin, and nothing happens. No bin shows up in the watch_face folder. Could you give brief instructions?
spanking time wrote: 05 May 2021, 17:40
What watchface you convert , Please show me
1. open GTRtoGTR2.exe
2. click convert GTR watch face to GTR2
3. choose .BIN GTR47mm
4. Click Open
Program will start convert
convert have only 4 step if you finish you can see Bin converted in the folder Watch_face
spanking time
asoo wrote: 05 May 2021, 18:12
4. Click Open
This one https://amazfitwatchfaces.com/gtr/view/9660
Ok I was able to convert it, as a new bin file appeared in the watch_face folder. However, upon syncing to watch via the Zepp app, it fails to sync. I am using these instructions for syncing the face on Android. I've tried it on several converted bin files now. All fail to sync to watch.
viewtopic.php?f=14&t=783
