GTR47 watchface to GTR2e
I have a GTR47. I'm using the attached watchface.
I would like to replace my GTR47 by a GTR2e but keep using the attached watchface.
It seems that now there are tools to convert GTR47 watchfaces to GTR2e.
The problem is that i'm using a mac and the tools are working on windows.
Can someone please tell me if this watchface can be fully functional on a GTR2e?
and is it possible to get a full AOD of this watchface on a GTR2e?
- Attachments
- tag_connected_weather_black (1).bin
- (1.96 MiB) Downloaded 129 times
spanking time
- Has thanked: 4 times
I'm not 100% sure but it seems that this tool should do the job :
viewtopic.php?f=29&t=1888&start=150
- Has thanked: 417 times
- Been thanked: 2090 times
Convert GTR to GTR2/2e can not make Full AODGR33ZY wrote: 05 May 2021, 11:36Hi,
This Version is GTR2e ( Not convert )
PS. Full AOD GTR2/2e can not show seconds handͼͽ To request please use the interrelated forum in action ͼͽ
Hi, Thanks a lot for your work.
Do you know how can I convert this GTR2e watch to full AOD (without seconds hand)
?? You mean this tag_connected_weather_black_GTR2_FullAOD.bin ??GR33ZY wrote: 05 May 2021, 16:59Hi, Thanks a lot for your work.
This file is GTR2 100% it's have full AOD . This file not convert from GTR47mm
if you convert from GTR47mm by program GTRtoGTR2 , it's can not make Full AOD so you want full AOD on GTR2 you must create new for GTR2 only
Sorry, I just tried your watchface on the GTR2e. It is perfect with full AOD. Thank you so much for your work
spanking time
Hm, doesn't do anything. I used the GTRtoGTR2 program, open a 47mm watch face bin, and nothing happens. No bin shows up in the watch_face folder. Could you give brief instructions?
What watchface you convert , Please show mespanking time wrote: 05 May 2021, 17:40Hm, doesn't do anything. I used the GTRtoGTR2 program, open a 47mm watch face bin, and nothing happens. No bin shows up in the watch_face folder. Could you give brief instructions?
1. open GTRtoGTR2.exe
2. click convert GTR watch face to GTR2
3. choose .BIN GTR47mm
4. Click Open
Program will start convert
convert have only 4 step if you finish you can see Bin converted in the folder Watch_face
spanking time
This one https://amazfitwatchfaces.com/gtr/view/9660asoo wrote: 05 May 2021, 18:12What watchface you convert , Please show mespanking time wrote: 05 May 2021, 17:40Hm, doesn't do anything. I used the GTRtoGTR2 program, open a 47mm watch face bin, and nothing happens. No bin shows up in the watch_face folder. Could you give brief instructions?
4. Click Open
Ok I was able to convert it, as a new bin file appeared in the watch_face folder. However, upon syncing to watch via the Zepp app, it fails to sync. I am using these instructions for syncing the face on Android. I've tried it on several converted bin files now. All fail to sync to watch.
viewtopic.php?f=14&t=783
