- Amministratore
dev.huami.com Integrate with Watch Face Greyed-Out
Rcappa
- Has thanked: 1 time
- Been thanked: 4 times
Hey Everyone,
I have been approved as a Huami Developer, but when I go to the "integrate with Watch Face" link, it's grey-out. Anyone know what I am missing?
Thanks in advance.
Thanks in advance.
- Has thanked: 419 times
- Been thanked: 2109 times
If you have been approved as a huami Dev. and you can not click " integrate with ..........". You can try to direct to the page with this url ( https://dev.huami.com/#/watch-skins/ )Rcappa ha scritto: 18 feb 2021, 16:32Spoiler
Hey Everyone,
Thanks in advance.
- eliasf
- Has thanked: 5 times
- Been thanked: 5 times
- Contatta:
Does anyone know how to edit the .zip file you get from the huami service when you export from their website?
It is empty in file explorer, I tried changing the extension to .bin and have a go at it with the beta py amazfit tool but that didn't work.
Any ideas?
Any ideas?
unzip file with Winzip or WinRAR ( when you "unzip" you can found .bin )eliasf ha scritto: 22 feb 2021, 06:59Does anyone know how to edit the .zip file you get from the huami service when you export from their website?
eliasf ha scritto: 22 feb 2021, 06:59It is empty in file explorer, I tried changing the extension to .bin and have a go at it with the beta py amazfit tool but that didn't work.
I don't understand what do you mean "It is empty in file explorer"
.zip you receive from huami is a zip compress you must to extract before use.
- eliasf
- Contatta:
Stupidly I wasn't using a program as nowadays windows file explorer handles everything I've come across but in this case the zipped folder was showing empty.
It worked as soon as I installed 7-zip.
Thanks asoo!
Thanks asoo!
demiurg1
- Has thanked: 23 times
- Been thanked: 17 times
- Contatta:
===================asoo ha scritto: 19 feb 2021, 00:55If you have been approved as a huami Dev. and you can not click " integrate with ..........". You can try to direct to the page with this url ( https://dev.huami.com/#/watch-skins/ )Rcappa ha scritto: 18 feb 2021, 16:32Spoiler
Hey Everyone,
Thanks in advance.
After logging in to the "Huami Open Platform", I used this link without any problems. I have edited a few watch faces via the website. It has been so until today. The link has stopped working. On the Huami website, I also do not have access to the editing tool (gray highlight). Do you have any idea to solve my problem?
Greetings.
P.S.
I really care about having access to this online editor. I have a couple of watch faces there.
