Watchface with seconds counter
Samir
Post by Samir »
Hello
I like watchfaces wich show me the seconds but this drain the battery very fast (drop for 1% every 3-4 hours).
If you selekt original watchface with the seconds counter there is no problem with battery drain.
Is there any special programming mode?
For programing and modifikation I am using this link: https://v1ack.github.io/watchfaceEditor/
anyone has experience with that?
rodrigo.llps
Post by rodrigo.llps »
I have noted that one of the analog watch faces that comes with the bip only shows the seconds when the watch is unlocked.
I don't know how to hide the seconds on my custom watch faces when the watch is locked, but it may be a good solution.
sfarkas
Post by sfarkas »
found a post at
viewtopic.php?f=6&t=103
about using multiple dial faces for different state.
Could it be a good starting point?
leechju
Post by leechju »
你好:
2-3個錶介面能解決秒針隱藏問題-但只是在美觀上.
利用不同表界面的顏色來讓指針看不見.
但真正指針.並沒有消失.沒辦法解決電池耗盡問題.
只能從json文件更改代碼命令上改動.
因為秒指針不是只有顯示秒而已-是代碼命令手錶系統-每秒更新所有手表所有數據.電池才會耗盡.
只有官方才有這個代碼命令.現在官方還沒釋出這個錶盤.無法提出json觀看代碼命令.
除非有人能破解手錶.提出官方代碼命令.才能解決秒指針電池耗盡問題.
如果是美觀問題.這個3介面錶盤能幫忙你.研究美觀
錶盤由-田龙先生.TXK先生-設計
三界面全功能商务简单指针(三)
http://bbs.huami.com/forum.php?mod=view ... muid=55273
(出处: huami论坛)
rodrigo.llps
Google translated the previous post:
Hello there:
2-3 table interfaces can solve the second hand hidden problem - but only in aesthetics.
Use the colors of the different table interfaces to make the pointer invisible.
But the real pointer. It has not disappeared. There is no way to solve the problem of battery exhaustion.
Can only be changed from the json file change code command.
Because the second pointer is not only the display seconds - it is the code command watch system - update all the data of all watches every second. The battery will run out.
Only the official code command has been issued. Now the official has not released this dial. Can not propose json to view the code command.
Unless someone can crack the watch. Ask the official code command to solve the problem of the second pointer battery exhaustion.
If it is an aesthetic problem, this 3 interface dial can help you. Study beautiful
Three interface full-featured business simple pointer (3)
Http://bbs.huami.com/forum.php?mod=view ... muid=55273
(Source: huami forum)
Dial by Mr. Tian Long. Mr. TXK - Design
rodrigo.llps
So, we could try to hide the seconds pointer but it would still be draining lots of battery.
The only way to solve this is to put our hand on the original watch face json file and study how it manages to show the seconds only when unlocked.
stupdude2
Post by stupdude2 »
rodrigo.llps wrote: 19 Oct 2018, 12:35
Does anyone know where I could find the original analog watch face file? I've got an analog watchface which I'd like to implement second hand only when unlocked to save battery. Thanks!
If I figure it out, I'll let you know how I did it.
TXK
Has thanked: 149 times
Been thanked: 97 times
Post by TXK »
stupdude2 wrote: 23 Oct 2018, 13:40
Your wishes will not come true.
Because the official dial is written in the system.
Its code is different from other codes.
Officials have not opened such codes.
sfarkas
Post by sfarkas »
You can find the resources of the core faces in the Mili_chaohu.res from MiFit .apk
stupdude2
Post by stupdude2 »
sfarkas wrote: 31 Oct 2018, 16:11
Thank you. I've tried decompiling the latest Mili_chaohu.res file using the python script but it seems broken with the latest versions. Has anyone else had any luck decompiling the latest firmware?
stupdude2
Post by stupdude2 »
For now I'll investigate using an older version which decompiles correctly.
sfarkas
Post by sfarkas »
You can try to decompile via Watchface.exe
stupdude2
Post by stupdude2 »
sfarkas wrote: 07 Nov 2018, 17:20
Thank you. I was able to extract the watchface and user interface images and header.json, but no watchface json.
Follow-up question: if I updated the extracted user interface files like the Status, Activity or Weather icons or app icons, could I recompile them using watchface.exe and push them to the watch using Gadgetbridge? What if I included ONLY the updated files? Would they update kind of like a patch, just replacing the included files?
sfarkas
Post by sfarkas »
There is no such json in resource file I think. The usage is in the fw as get resuorce xx, or get resource nn.
Theoretically yes. If calling it without any parameter, you will get some help - I mean "Watchface.exe".
Never tried to upload a recompiled res to the watch.
savethedinosaurs
Post by savethedinosaurs »
This was useful info, thanks all! There are some animated watchfaces I really want to make, but I don't want them to drain the battery. If anyone figures out a way to use seconds or access some other timer so it doesn't drain the battery please make a post about it :)
