WatchFaces New Features
Bloccato
Tugas
Has thanked: 7 times
Messaggio da Tugas »
Hello Lets post the new features
Compress PNG files online : https://tinypng.com/
Animations
With this online tool you can edit and make animations and then split to png files
https://ezgif.com
This is other great site with many animations
https://giphy.com
Some examples
Shortcuts to Steps, Battery, Weather and Heart BPM
Example of a great watchface with all this ;)
https://amazfitwatchfaces.com/gtr/view/3251
You can use this tool to extract and pack again.
https://github.com/amazfitbip/py_amazfit_tools/releases
(Thanks asoo)
Ultima modifica di Tugas il 13 feb 2020, 19:08, modificato 5 volte in totale.
Has thanked: 404 times
Been thanked: 2023 times
Messaggio da asoo »
Tugas ha scritto: 27 gen 2020, 19:13
Animations
https://4pda.ru/forum/index.php?showtop ... ry93164604
Shortcuts -> still don't extract, I put the bin file
SashaCX75 talk about "SHORTCUT"
http://4pda.ru/forum/index.php?showtopi ... ry93281373
new main.exe for extract this BIN
Extracted
Sports_click.zip
(766.09 KiB) Scaricato 173 volte
My watchface add Animation and shortcut
999Nocturne
Messaggio da 999Nocturne »
Hi, could you help me with the animation?
I really can't understand, I compose the json with GTR_Watch_Face_v6.0 and then I add the animation code with my images, 23 is an empty image, and from 27 to 36 my animation, but it doesn't work.
doing the tests I found out that my images 27 to 36 are not inserted in the .bin file, can someone help me?
I answer myself, it could help someone.
When the animation images are not inserted in .bin, just put them in the middle, example:
img0 Background, img1 Preview, from img2 to img6 animation, img7 hands and so on.
If you put it like this it does not insert the images in the .bin, wrong example:
img0 background, img1 preview, img2, img3, img4 hands, finally from img5 to img 9 animation
Messaggio da asoo »
After you unpack in some time the Animation code is change and if you pack again it's not work
I do not know why too. so After i unpack i will delete animation code out and add my cut code represent
I cut Only StaticAnimation (Unknown11_2) because MotiomAnimation (Unknown11_2) some time add it not work
Codice: Seleziona tutto
  "Unknown11": {
    "Unknown11_2": {
      "Unknown11d2p1": {
        "X": 327,
        "Y": 264,
        "ImageIndex": 8,
        "ImagesCount": 4
      "Unknown11d2p2": 400,
      "Unknown11d2p3": 0,
      "Unknown11d2p4": 6000,
      "Unknown11d2p5": 100
"Unknown11d2p2": 400, <----- delay Animation ( Speed)
"Unknown11d2p4": 6000, <-------How long of Animation
"Unknown11d2p5": 100 <------------- wait in round
I add code like this :
"Info": {
"DeviceId": 40
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Preview": {
"X": 0,
"Y": 0,
"ImageIndex": 1
"Unknown11": {
"Unknown11_2": {
"Unknown11d2p1": {
"X": 327,
"Y": 264,
"ImageIndex": 8,
"ImagesCount": 4
"Unknown11d2p3": 0,
"Time": {
999Nocturne
Thanks a lot, but this worked for me:
    "Unknown11": {
    "Unknown11_1": [
        "Unknown11d1p1": 0,
        "Unknown11d1p2": {
          "X": 43,
          "Y": 90
        "Unknown11d1p3": {
          "X": 42,
          "Y": 300
        "ImageIndex": 1,
        "Unknown11d1p5": 3500,
        "Unknown11d1p6": 0,
        "Unknown11d1p7": 0,
        "Unknown11d1p8": 1,
        "Unknown11d1p9": 0,
        "Unknown11d1p10": 0
        "Unknown11d1p1": 0,
        "Unknown11d1p2": {
          "X": 159,
          "Y": 0
        "Unknown11d1p3": {
          "X": 188,
          "Y": 5
        "ImageIndex": 2,
        "Unknown11d1p5": 2000,
        "Unknown11d1p6": 0,
        "Unknown11d1p7": 0,
        "Unknown11d1p8": 1,
        "Unknown11d1p9": 0,
        "Unknown11d1p10": 0
        "Unknown11d2p1": {
          "X": 173,
          "Y": 308,
          "ImageIndex": 3,
          "ImagesCount": 6
        "Unknown11d2p2": 200,
        "Unknown11d2p3": 0,
        "Unknown11d2p4": 10000,
    "Unknown11_2": [
        "Unknown11d1p1": 0,
        "Unknown11d1p2": {
          "X": 43,
          "Y": 90
        "Unknown11d1p3": {
          "X": 42,
          "Y": 300
        "ImageIndex": 1,
        "Unknown11d1p6": 0,
        "Unknown11d1p7": 0,
        "Unknown11d1p8": 1,
        "Unknown11d1p9": 0,
        "Unknown11d1p10": 0
        "Unknown11d1p1": 0,
        "Unknown11d1p2": {
          "X": 159,
          "Y": 0
        "Unknown11d1p3": {
          "X": 188,
          "Y": 5
        "ImageIndex": 2,
        "Unknown11d1p6": 0,
        "Unknown11d1p7": 0,
        "Unknown11d1p8": 1,
        "Unknown11d1p9": 0,
        "Unknown11d1p10": 0
        "Unknown11d2p1": {
          "X": 173,
          "Y": 308,
          "ImageIndex": 3,
          "ImagesCount": 6
        "Unknown11d2p3": 0,
Tugas
asoo ha scritto: 10 feb 2020, 13:25
  "Unknown11": {
    "Unknown11_2": {
      "Unknown11d2p1": {
        "X": 327,
        "Y": 264,
        "ImageIndex": 8,
        "ImagesCount": 4
      "Unknown11d2p3": 0,
"Info": {
"DeviceId": 40
"Background": {
"Image": {
"X": 0,
"Y": 0,
"ImageIndex": 0
"Preview": {
"X": 0,
"Y": 0,
"ImageIndex": 1
"Unknown11": {
"Unknown11_2": {
"Unknown11d2p1": {
"X": 327,
"Y": 264,
"ImageIndex": 8,
"ImagesCount": 4
"Unknown11d2p3": 0,
"Time": {
Hello!
Can you please put the json file of your watchface already fixed so that we can see the differences after unpacking and make sure it will work, thanks
Messaggio da asoo »
Tugas ha scritto: 12 feb 2020, 17:51
Hello!
https://amazfitwatchfaces.com/gtr/view/2883 <<------- test Only StaticAnimation
yill5880
Messaggio da yill5880 »
"Unknown11": {
"Unknown11_2": {
"Unknown11d2p1": {
"X": 327,
"Y": 264,
"ImageIndex": 8,
"ImagesCount": 4
"Unknown11d2p3": 0,
Messaggio da asoo »
yill5880 ha scritto: 13 feb 2020, 08:51
Is there any way I can add multiple pieces at once using the form below?
As far as I know now, have only one code can be used for Static Animation.
can not add multiple.
Lordalpine
Been thanked: 35 times
Messaggio da Lordalpine »
Animation made on Watchmaker App
Screen in real time saved with the Onscreen Video Samsung capture App [ Note 10 ]
Crop on Inshot
Converted in Gif in Gifshop [ 1000*1000 gif]
Resized and frame kept in Photoshop [ 150*152 png ]
Let's say I try... [ I'm so Sad of the final result... It's better with 10 frames now but not satisfying for me ]
The gif is 150 frames [ Tourbillon make a total rotation ]
Only kept 10 frames of this animation [ 150*152 size ] to animate the tourbillon of :
https://amazfitwatchfaces.com/gtr/view/3779
"Unknown11": {
    "Unknown11_2": {
      "Unknown11d2p1": {
        "X": 150,
        "Y": 291,
        "ImageIndex": 7,
        "ImagesCount": 10
      "Unknown11d2p2": 350,
      "Unknown11d2p3": 0,
      "Unknown11d2p4": 60000,                     [It's like playing euromillion, and pray for nice effect^^ ]
      "Unknown11d2p5": 10000
It's not like the price would change a lot if Huami engineer put a 16Mb of Internal memory to at least support Huge detailed face.
edit : 10 frames used here instead of 5 now
In Photoshop export in PNG with 8 bit colours [ -50% of each Png weight ]
Totally killed the 0001Png [ 1*1 Px :mrgreen: ]
[mention]asoo[/mention] Maybe a silly question : Does a code exist to make a total rotation of an element with 1 Png...
Ley's say i Only keep 1 frame [or only the tourbillon and put the rest of elements on the background 0000.Png ] and the code make it rotate from 0 to 360° ?
Messaggio da asoo »
Lordalpine ha scritto: 16 feb 2020, 20:41
@asoo Maybe a silly question : Does a code exist to make a total rotation of an element with 1 Png...
As far as I know, there is no code used to do that you said.
        "ImageIndex": 8,
        "ImagesCount": 4
      "Unknown11d2p3": 0,
      "Unknown11d2p5": 10000   <--- Have you stopped for too long for one round ?  If you want continuity, I think you  maybe should use 100.
Good idea for this watchface :o :idea:
Lordalpine
With the code you provided me, It's definitively better.
Preview cheat^^ :
https://amazfitwatchfaces.com/gtr/view/3819
If you are lazy and don't use some function....Just use the steps counter for animated preview, just simply put frame for number.
Adjust the preview state on the Gui with simple value like 1 - 2 - 3 - 4 etc.
  "Unknown11": {
    "Unknown11_2": {
      "Unknown11d2p1": {
        "X": 150,
        "Y": 291,
        "ImageIndex": 7,
        "ImagesCount": 9
      "Unknown11d2p2": 1000,
      "Unknown11d2p3": 0,
      "Unknown11d2p4": 0,
      "Unknown11d2p5": 0        So a "0" deactivate the function [ never think of putting here a 0  :mrgreen:  ]
Maikeldevil
Been thanked: 44 times
Messaggio da Maikeldevil »
Is there a option to set speed on an animation? The mi band 4 has a speed option.. altough my biggest wish is a smooth sweeping seconds hand.. hope it could be done someday..
Bloccato
Torna a “Closed topics”
