WFZMaker
chb
Has thanked: 10 times
Post by chb »
site didn't found!
VIzzAR wrote: 08 May 2019, 09:34
New version available! Now the application should run.
Ver. 1.5.2 https://drive.google.com/file/d/16lHNI9 ... sp=sharing
Don't worry, eat Curry!
Has thanked: 1162 times
Been thanked: 278 times
chb wrote: 26 May 2019, 19:35
site didn't found!
Updated all links in the first post.
gildo52
Post by gildo52 »
it would be interesting to have possibility to set hands and time position when producing sample-face. thanks
gildo52
Post by gildo52 »
rel 1.6.5 gives error when trying to import .wfz file
wrotolo
Post by wrotolo »
Hi VIzzAR,
I have an enhancement request for the next version.
I noticed that the faces you build with your tool don't respect the "hand gesture" mode when switched on in the config.
I did a bit of digging and came to the conclussion that the issue is in the config as by adding the right code manually to the output wfz file from you app it works.
What is needed is a line on the Watchface.xml file as follows <WatchFaceItem type="support26w" config="true" />, right after:
<?xml version="1.0" encoding="UTF-8"?>
<WatchFace version="1.1">
<WatchFaceItem type="support26w" config="true" /> <----------------- here
And in parallel, a folder called 26w to be created in both background and timehand folders, and put also copies of the background and hands files. (I have only tested an analog face but I presume the same folder will have to be created for the "font" folder so it also will work with digital ones)
So that's my suggestion, let me know if it's not clear enough or if you need further clarification and keep up the good work as it is great!!!!
Cheers,
ti.fch
Post by ti.fch »
Work in mi band 4?
osmat
Admin
Has thanked: 35 times
Been thanked: 73 times
Post by osmat »
No it's just for stratos and pace
ti.fch
Post by ti.fch »
Please think , create for mi band 4
lvpokka
Has thanked: 19 times
Been thanked: 152 times
Post by lvpokka »
ti.fch wrote: 09 Aug 2019, 11:58
There is already tool for mi band 4))
koolgao
Post by koolgao »
buenos dias va hacer algo para el gtr?
ManuTdi
Post by ManuTdi »
koolgao wrote: 18 Aug 2019, 08:47
+1000
Torafugu888
Post by Torafugu888 »
Hi VizzAR
Created watchface with digital time, background pic, and widgets for amazfit verge.
I have "lift wrist and the screen is on" set to on.and double tap to wake.
when I lift my wrist I only see the time, and not the back ground or the widgets. I have to double tap or press the button to see everything and not just the time bit, it seems as though when I lift the wrist I can only lock screen with the time and not everyting,.
Is it something to do with how I created the watch face or is there a setting I am missing.
thank you
joaorennato
Post by joaorennato »
[SOLVED]
Hello guys
First of all thank u VIzzAR for the amazing tool you provided.
It's my first ever try on making a watchface and I having some problems
In the app my watch face looks like this:
Anotação 2019-10-15 150353.png (176.6 KiB) Viewed 22486 times
But when I export to wfz it looks like this:
Anotação 2019-10-15 151853.png (310.23 KiB) Viewed 22486 times
I have Amazfit Verge. Any ideas of what I'm doing wrong?
Thank you very much and sorry for my english!
EDIT:
I was trying to use a transparent png image as background. Once I filled the background with black all became normal.
wrotolo
Post by wrotolo »
Torafugu888 wrote: 13 Oct 2019, 11:59
Hi VizzAR
thank you
Hi [mention]Torafugu888[/mention]
See my post on 07 Aug 2019, 10:36, where I have suggested the enhancement to the developer and how to fix it manually.
Ripo power
Post by Ripo power »
Hello team WFZMaker,
I wish you coulds make a new update including resize widgets and full control of font, color, 360° rotation ...
viriv
Post by viriv »
can you pls make this tool compatible with the amazfit bip? thx in advance
-viriv
stephcel
Post by stephcel »
hi guys,
good job...
How can we create new ID for startos 3 ?
Stratos37.wfz
(76.59 KiB) Downloaded 415 times
LinkPK
Post by LinkPK »
Hi guys. I was making my very first watch face skin based on The Division and when everything was ready, a big error list appeared before saying "File Saved". Yeah, it saved it, but then nothing's on screen. I tried adding a background to the numbers, I tried using different fonts, I tried no background and nothing and nothing.
I don't know if it's a bug of the last version, so I tried to download a previous one, but they're private.
Picture is attached to this post.
Any help, please? Thanks!
PS: Also, I'd love to change the colour of the widgets to make them match with the theme. Could it be possible?
Error List
Error List
horvathg1984
Post by horvathg1984 »
Nice job making this tool. I have Amazfit Pace and the exportet WFZ files are working like a charm.
Anyway. Is it possible to set the Hour digits and Minute digits to different colors? There are many WFZ files with for example red hours digit and white minute digits. But the tool let us only set the main color of the digits.
jrfialho
Post by jrfialho »
198/5000
Good night,
I would like to know if it is possible to use your program to make watchfaces for the amazfit nexo watch. If not as a reference which watchface should I use?
Thanks in advance.
wag
Post by wag »
Hi!
How can I change the widgets colours?
bitas
Post by bitas »
Hello, is it possible to change the day of the week to another language?
Example:
English: friday-fri.
Lithuanian: penktadienis-pen
English: November
Lithuanian: Lapkritis
Ricardo2290
Post by Ricardo2290 »
Hello. Someone have the old versions?
I have problems with the newer one. I make one wathface and it is ok, but when the lights turn off, the screen turn black. I don't see anything. My smartwatch is the Amazfit Pace.
Best regards, Ricardo.
workale
Post by workale »
Hi, I have a problem in the creation of the watchface, the wake up mode with the movement of the wrist, remains with the 8 coloring, can you do something, thanks for the great work.
Chuque
Post by Chuque »
If the editor changes any config file containing object parameters, like a json or an xml, please make a window where we can see them edited on real time, so we can fine adjust by text.
