VIzzAR wrote: 08 May 2019, 09:34New version available! Now the application should run.
Ver. 1.5.2 https://drive.google.com/file/d/16lHNI9 ... sp=sharing
WFZMaker
- GIK-Team
- root
- Has thanked: 1162 times
- Been thanked: 278 times
Updated all links in the first post.
it would be interesting to have possibility to set hands and time position when producing sample-face. thanks
Hi VIzzAR,
I have an enhancement request for the next version.
I noticed that the faces you build with your tool don't respect the "hand gesture" mode when switched on in the config.
I did a bit of digging and came to the conclussion that the issue is in the config as by adding the right code manually to the output wfz file from you app it works.
What is needed is a line on the Watchface.xml file as follows <WatchFaceItem type="support26w" config="true" />, right after:
<?xml version="1.0" encoding="UTF-8"?>
<WatchFace version="1.1">
<WatchFaceItem type="support26w" config="true" /> <----------------- here
And in parallel, a folder called 26w to be created in both background and timehand folders, and put also copies of the background and hands files. (I have only tested an analog face but I presume the same folder will have to be created for the "font" folder so it also will work with digital ones)
So that's my suggestion, let me know if it's not clear enough or if you need further clarification and keep up the good work as it is great!!!!
Cheers,
Cheers,
Torafugu888
Hi VizzAR
Created watchface with digital time, background pic, and widgets for amazfit verge.
I have "lift wrist and the screen is on" set to on.and double tap to wake.
when I lift my wrist I only see the time, and not the back ground or the widgets. I have to double tap or press the button to see everything and not just the time bit, it seems as though when I lift the wrist I can only lock screen with the time and not everyting,.
Is it something to do with how I created the watch face or is there a setting I am missing.
thank you
thank you
joaorennato
[SOLVED]
Hello guys
First of all thank u VIzzAR for the amazing tool you provided.
It's my first ever try on making a watchface and I having some problems
In the app my watch face looks like this:
But when I export to wfz it looks like this:
I have Amazfit Verge. Any ideas of what I'm doing wrong?
Thank you very much and sorry for my english!
EDIT:
I was trying to use a transparent png image as background. Once I filled the background with black all became normal.
Hello guys
EDIT:
Hi [mention]Torafugu888[/mention]Torafugu888 wrote: 13 Oct 2019, 11:59Hi VizzAR
thank you
See my post on 07 Aug 2019, 10:36, where I have suggested the enhancement to the developer and how to fix it manually.
Ripo power
- Has thanked: 1 time
Hello team WFZMaker,
I wish you coulds make a new update including resize widgets and full control of font, color, 360° rotation ...
hi guys,
good job...
How can we create new ID for startos 3 ?
good job...
- Attachments
- Stratos37.wfz
- (76.59 KiB) Downloaded 415 times
Hi guys. I was making my very first watch face skin based on The Division and when everything was ready, a big error list appeared before saying "File Saved". Yeah, it saved it, but then nothing's on screen. I tried adding a background to the numbers, I tried using different fonts, I tried no background and nothing and nothing.
I don't know if it's a bug of the last version, so I tried to download a previous one, but they're private.
Picture is attached to this post.
Any help, please? Thanks!
PS: Also, I'd love to change the colour of the widgets to make them match with the theme. Could it be possible?
- Attachments
- Error List
- Errors.PNG (33.04 KiB) Viewed 22422 times
horvathg1984
Nice job making this tool. I have Amazfit Pace and the exportet WFZ files are working like a charm.
Anyway. Is it possible to set the Hour digits and Minute digits to different colors? There are many WFZ files with for example red hours digit and white minute digits. But the tool let us only set the main color of the digits.
198/5000
Good night,
I would like to know if it is possible to use your program to make watchfaces for the amazfit nexo watch. If not as a reference which watchface should I use?
Thanks in advance.
Good night,
Thanks in advance.
Hello, is it possible to change the day of the week to another language?
Example:
English: friday-fri.
Lithuanian: penktadienis-pen
English: November
Lithuanian: Lapkritis
Example:
English: November
Ricardo2290
Hello. Someone have the old versions?
I have problems with the newer one. I make one wathface and it is ok, but when the lights turn off, the screen turn black. I don't see anything. My smartwatch is the Amazfit Pace.
Best regards, Ricardo.
Hi, I have a problem in the creation of the watchface, the wake up mode with the movement of the wrist, remains with the 8 coloring, can you do something, thanks for the great work.
If the editor changes any config file containing object parameters, like a json or an xml, please make a window where we can see them edited on real time, so we can fine adjust by text.
